Old 08-31-2009, 12:17 AM   #1 (permalink)
THE DODGE - '06 Ram 2500 ST
90 day: 22.64 mpg (US)
The Saturn - '08 Vue XR
90 day: 21.94 mpg (US)
The Odyssey Van - '011 Odyssey EX-L
90 day: 29.1 mpg (US)
Tires and FE ?'s
My current tires are 325/55/22 and weigh 68lbs each and are 36.1" tall on a 55lb wheel. So Tire/wheel combo is ~123lbs each. I'm wanting to go to a 305/45/22 in the same tire which weigh 50lbs each and are 32.8" tall. This will save me 18lbs or 17.1% in rotational weight for each tire/wheel combo but will affect my overall drive ratio by 10%. Also the later tire will have less frontal area being shorter and slightly narrower. I drive 90% highway and 10% city through slow rolling hills. How should this affect my FE?
Old 08-31-2009, 12:31 AM   #2 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
This is a trick question right?
Old 08-31-2009, 12:41 AM   #3 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
loled
To answer question, yes it will. How much? I don't know.
Old 08-31-2009, 07:30 AM   #4 (permalink)
Tire Geek
CapriRacer's Avatar
Steady State FE is actually going to be worse and the only thing that will be better will be stop and go driving. When it comes to tires, because they are pretty much covered by the fenders, aerodynamics hardly plays a role.
That means for the 90% highway driving you do, this is the wrong direction. However, the 10% city will improve somewhat.
You would have been further ahead to buy smaller diameter wheels and high aspect ratio tires.
Tire size and FE with a Jeep zjrog Off-Topic Tech 22 01-24-2011 11:32 PM
Overall good tires hummingbird General Efficiency Discussion 7 06-19-2009 09:25 AM
Hankook Tire's Enfren tire technology botsapper General Efficiency Discussion 0 06-11-2009 03:50 PM
FE hit from 32" tires? ModelE EcoModding Central 12 04-13-2009 11:58 AM
Larger diameter tires = better FE? JV-Tuga EcoModding Central 16 07-12-2008 11:45 AM
