Old 01-11-2010, 10:10 PM   #1 (permalink)
ecomonkey
silver clown - '02 echo 2 door base
90 day: 45.91 mpg (US)
tires rated for higher psi?
my 175/65r14 tires on my toyota echo are rated for max psi of 44 are there tires that have a higher psi rating? mine are the walmart goodyear viva -2's they are supposted to be llr (low rolling resistance) ,but they are no better than my old tires at least not yet and i have 30k on them.
Old 01-15-2010, 03:32 AM   #2 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
I just bought a set of Nokian wrg2 tires and they are supposed to be LRR. They are working really well for me although I have not collected enough data yet. Incredibly quiet even on wet roads. Max 51 PSI with a canola silica compound. They have your size in an all season i3 I think. 620/A/A They are a very green comany as tire companies go. The first to offer non toxic tires.
Also there is the bridgestone RE92 XL which is an OEM for the fist gen Prius. They seem to be an OK tire and LRR. (50 PSI) Mediocre reviews though.
There is also the BS B381 which is the lowest RR tire going.
Old 01-15-2010, 04:04 AM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
moonmonkey -
I used tirerack.com to research tires rated at 51 PSI :
My Continental Contact-Pro Tires
Mine don't seem to be available in your size, .
CarloSW2
American Solar Energy Society
Old 01-15-2010, 09:03 PM   #4 (permalink)
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
The Sumitomo HTR 200 is available in a 175/65-14 and a taller 175/70-14. Max pressure is 51 PSI. It's no B381, but it's cheaper and available in your size. And it's one of Green Seal's recommended tires. I wish they made them for 12" wheels.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
How many PSI do you run in YOUR tires? 1337 EcoModding Central 82 05-23-2011 12:03 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
