Old 07-28-2009, 02:45 PM   #11 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
Ok, I think I have it down to $4k
anything I should check before buying
(besides the normal car stuff of course)
* eventually I wanted to add an alarm/remote locks
Past Present Future?
Old 07-28-2009, 02:57 PM   #12 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I would say to check the battery, but I honestly don't know how. Can one of the Insight guys chime in here?
Old 07-28-2009, 03:20 PM   #13 (permalink)
Only things I can think of for a battery pack check is a hard acceleration, on an uphill if you have one, and see if the charge level quickly drops to zero instead of gradually decreasing. Or a long hill climb that keeps assist on at a lower level: you might see indicated charge drop slowly for a while, then a quick drop to zero.
(You could trigger an IMA light doing this. If so, don't panic. Just pull I think the #18 fuse from the inside box (by your left knee), wait 10 secs, and put it back, and you'll be good to go.)
If it does do the quick drop after some amount of normal assist, it's not necessarily a reason not to buy the car, since it can still go for years with the lesser capacity, especially if you drive mostly on the level.
Old 07-28-2009, 03:46 PM   #14 (permalink)
Grasshopper
thanks for the info
had to read it twice but i think i got it
ill have to check that out
driving on the level however... is not my theme
FS: All USED Honda Insight Parts For Sale Fabio For Sale 15 12-20-2011 09:29 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
FS: 2001 Honda Insight mtgeekman For Sale 2 08-31-2009 11:56 PM
2001 Honda Insight Blue Bomber Man General Efficiency Discussion 3 07-19-2009 10:24 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 11:45 AM
