Old 11-21-2011, 09:13 AM   #141 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by bandit86 View Post
If A tire does not like to flex much would that not mean it should have lower rolling resistance? ..........
Sorry, but no. The fact that it doesn't like to flex - and the load on the tire is going to force it to flex - means that there will be more internal heat generated - and that's RR.
.....What about siping, does that make a difference?
The difference is small enough to ignore.
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 38 04-13-2011 06:12 AM
Video: Can Skinnier Tires Increase Fuel Economy? Peakster EcoModding Central 62 03-12-2011 02:58 PM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 02:49 PM
