Old 02-01-2012, 05:29 PM   #221 (permalink)
Since all the info on this car inspired me to start this:
Mk3 Golf sipster project. - TDIClub Forums
But the info was hard to find and locate and follow (not very user-friendly UI if you ask me ) I thew this up there a while ago:
The Rabbit Sipster
Old 05-10-2012, 10:37 PM   #222 (permalink)
PHEV 2nd Gen Insight
Interesting they choose a Rabbit vs the Dasher. I had a Dasher and it got easily 50+ mpg in its stock form. It took like 5 miles toget to 55mph. It was a 1.3 L engine 90 CID if I remember correctly. The cylinders were smaller than a coke can and if you didnt retorque the head, you were asking for a gaskin replacement.
I bet with eco mods that got int he mid 70s, but I sent mines to thecrusher in 00.
Sorry, new users are not permitted to post links in their signatures.
Old 05-10-2012, 10:45 PM   #223 (permalink)
There never was any VW (water cooled) that were imported to the US with any
smaller than 1.5 engines which is what the Dasher had, there were no 1.3 diesels back then only more recently VW had a 1.2L 3 cylinder one.
Sounds like you had a fairly tired engine and IP based on your experience.
As for why they didn't use a Dasher or by it's original name Passat would be maybe because very few are still around and that with it you couldn't have done the same transmission conversion nor would there even be any sutaible TDI geared transmission that would fit it in the US, since it is more based on an Audi than a VW and doesn't have a transverse engine as the Rabbit.
Old 05-24-2012, 07:15 AM   #224 (permalink)
master modder
brent - '97 d21 xe
90 day: 26 mpg (US)
best gear lube for mpg?
hey guys i have a 97 nissan pickup (26 mpg) after mods
and im looking to get the best gear lube for mpg nissan says to use 80/90 btw
-its hard to have a fun life if you don't have fun in life-
Old 05-24-2012, 07:19 AM   #225 (permalink)
master modder
brent - '97 d21 xe
90 day: 26 mpg (US)
back pressure Q
i have a 97 nissan pickup 4 cylinder can i take my cat off and still have enough back pressure? MPG! lol thanks
Unread 05-24-2012, 09:29 AM   #226 (permalink)
You don't need backpressure... but depending on state emissions, you do need the cat.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
