Old 02-25-2009, 07:41 AM   #41 (permalink)
Moderator
tasdrouille's Avatar
The Truck (Retired) - '99 A3 Jetta TDI
90 day: 62.27 mpg (US)
The Guzzler - '08 Elantra GL
90 day: 31.47 mpg (US)
The Green Machine - '00 A4 Jetta TDI
90 day: 52.33 mpg (US)
That's good brainstorming right there. You sure have a lot of imagination.
75 kw peak won't get you 5s though, especially with the added weight from the batteries and the electric motor. HP is what makes a car accelerate. Torque makes it pull nicely, but HP does the work.
Edit: I didn't read carefully. ICE in the front + electric in the rear would indeed pull incredibly fast times.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
- Quand chaque goutte compte...
Old 02-25-2009, 06:46 PM   #42 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 81.72 mpg (US)
Originally Posted by TomO View Post
If EM does go this route and Basjoos agrees, I will donate my spare D15Z1 and some time over the summer to this project to get his car setup with a VX motor. It would be possible to push him over the 100MPG mark easily while still retaining an OEM drivetrain.
Seriously??? I agree: a lean burn Aerocivic would get phenomenal highway mileage.
I wonder if Mike would be game...
Latest project:
Latest test:
- fuel efficiency info for Geo Metro owners
- electric car conversion on a beer budget
Old 02-25-2009, 08:02 PM   #43 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
90 day: 71.28 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 69.1 mpg (US)
I'm game. My current engine, although it is still running fine, puts out a slight blue plume right after a cold start and has been gradually using more oil (a quart every 1500 miles). I was planning to try replacing it with a D15Z1 when it reached the end of its life. Wayne Gerdes said the Aerocivic would probably remain in lean burn even at 80mph. An engine swap sounds like a good summer project, possibly in conjunction with a drive up to Hybridfest. It would also give you a good chance to take a close look at, drive my car, and compare its performance to that of a normal VX.
Old 02-26-2009, 10:22 AM   #44 (permalink)
Wow. Fingers crossed for an Aerocivic VX!
Tas: I believe he meant the car would be using the peak 75 kW electric output in addition to the ICE to achieve the silly acceleration numbers.
Latest project:
Latest test:
Old 02-26-2009, 10:56 AM   #45 (permalink)
300MPG.org
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 26.95 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Yea! Another EcoModder meet-up at HybridFest! I'm planning on being there with the Electro-Metro this year!
go farther on far less.
Greening up my house.
Old 02-26-2009, 11:20 AM   #46 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 47.03 mpg (US)
Daox's Prius - '04 Prius
90 day: 46.53 mpg (US)
That would be great.
- Efficient living and green home improvement
Old 02-26-2009, 12:10 PM   #47 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 28.77 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
You may be right since we would be between 5-6s with ~180whp/~2200-2500lbs, depending on how much was done in the way of weight reduction. The motor/batteries/electronics would add ~400lbs, but that could be offset with weight reduction like a tall 4spd instead of a 5sp (~50lbs), decent sound insulation instead of the asphalt crap on the floor (~25lbs), a patch kit instead of a full size spare (~35lbs IIRC), yanking the starter motor (~30lbs, just roll start it), yanking the break booster (~15lbs), and so on... Going balls out can result in a ~1400lbs bunny IIRC, so there's definitely plenty of weight to drop.
Old 02-26-2009, 12:35 PM   #48 (permalink)
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
Last 3: 57.98 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
If I had to guess I'd say that top gear will make their speed goal with POWER. The ALH mods easily. Nozzles + tune can get 150Whp with no noticeable loss in economy, 200 whp isn't all that hard,
Old 02-26-2009, 01:06 PM   #49 (permalink)
Hey everyone. Here's another feature installment for Project Sipster, hope you enjoy.
Road to Perdition, er, Regina - Top Gear US
Old 02-26-2009, 01:28 PM   #50 (permalink)
Haha. Gotta love tales of epic road trips. Good writing.
Thanks for the update, giff, "wide-eyed young edit-slave".
Latest project:
Latest test:
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 131 01-03-2010 06:13 PM
Car Hire Ireland
Visiting Ireland? Holiday Autos have the best car hire for you to explore the country.
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
