Old 08-26-2014, 03:58 PM   #11 (permalink)
EcoModding Smurfer
Smurf's Avatar
Dime - '95 Chevy S10 LS ExtCab RWD
Pickups
90 day: 18.23 mpg (US)
G/A - '96 Pontiac Grand Am
Team Pontiac
90 day: 32.74 mpg (US)
... I used the little snap cover the UG comes with, then got a 1"x1" right-angle bracket thingee from the hardware store. Screwed one end of the bracket into the top surface of a section of the dash, the UG with the bracket slides down over the other end. Full button functionality, maybe 15 cents, no headaches.
Old 08-29-2014, 06:29 PM   #12 (permalink)
90 day: 47.72 mpg (US)
Blammo!
Found a nice black soapbox and added that to the stack of things on the UG mount.
Couple of foam spacers from a window replacement to operate the buttons on the back side.
Protection against direct sunlight, touchscreen, mounted where I want it; got is all! And it works!
BamZipPow (08-30-2014)
