Old 08-26-2009, 05:39 PM   #11 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Originally Posted by micondie View Post
I think that if you did an A-B-A test between WAI and CAI in which you controlled the acceleration to match it between tests you would find no advantage to WAI.
That my 2 cents
Mike
I accidentally had a single-blind test that confirms it for my vehicle...
Under similar weather conditions, an early version of a WAI broke loose and started to inhale cooler air under the front bumper (not freezing cold, but in the 50F-75F range). This was before the SG -- an OBD chip documented the scenario.
It was a couple of weeks before I popped the hood and found the problem. I would like to say that I was accelerating similarly, but I only have incremental speed readings to compare. I filled up and noted the results. With the rough data presented, the conclusion was that the cooler air decreased FE.
YMMV.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 08-26-2009, 06:27 PM   #12 (permalink)
micondie's Avatar
moby van - '03 Caravan SE
90 day: 19.74 mpg (US)
YMMV.
RH77
Without getting into all the other possible variations between tanks, just try this. Watch your SG when you are accelerating and see if your right foot can sense the difference between 10 & 12 mpg or whatever range you usually try for. The acceleration is what kills mpg so the 20% difference between 10 and 12 can really affect your overall mpg.
