Old 08-29-2009, 06:37 PM   #1 (permalink)
Arrow Toyota Camry Gen2 1989 Aero Recommendations?
Just wanted to know what you guys would recommend doing first. I'm not interested in doing damage to the car, but I wouldn't mind adding a few things onto it to make it more aero dynamic.
This isn't mine, but looks just like it:
I was thinking about doing something to the front bumper / grill using some aluminum in the 1/8" to 1/16" range. What would you guys do?
I typically drive very short distances under 5 miles usually so my MPG sucks usually. But 1/2 the miles are on the freeway, so I thought I could benefit a little from some aero mods, and I'd really benefit on the occasional longer trip.
Thanks!
Old 08-31-2009, 11:01 PM   #2 (permalink)
Camry
looks like the front airdam could be lowered about 3-inches(75-mm),and then that elevation could carry all the way down the rocker panels,and behind the rear wheels to the back of the car.I would trim back the mudflaps so they don't tear at the flow.A rear deck spoiler on the trunklid,rising up and to the rear at no steeper than a 30-degree angle,and tall enough that a long straight-edge laid across the back of the roof and spoiler top indicated an angle no steeper than say 12-degrees as measured from the horizon.Your wheelcovers are very good,I'd hang on to those.If the lower grille opening appears to have "overkill"(way too much opening compared to rediator width) you could close off some of the outer portion of that opening.------------ Your short commute is a killer to mpg,it takes 22 continuous miles of driving just to get all your lubes up the equilibrium temp.If you could magically pre-heat your engine,transaxle,and all bearings,you'd see remarkably higher mpg.
Old 06-12-2010, 01:28 AM   #3 (permalink)
Horton
Guest
Posts: n/a
When I go for updates or modifications, I change or replace the bumpers so that the car will look bulky. I also change the color and design of the car to give it a new and refreshed look.
Old 06-12-2010, 12:15 PM   #4 (permalink)
Lower it.
Old 06-14-2010, 08:42 AM   #5 (permalink)
Camry MPG Modder
Camry CE - '00 Camry CE
90 day: 36.18 mpg (US)
Check out my Gen4 Camry thread under aero area...
Thanks!
But with your short range, local driving the only real gains you are going to make are by Pulse and Glide or getting a lighter car.
I know that costs $$$. Thats the reason I have a 10 yr old Camry and not a 5 yr old Prius.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
Need Aero Recommendations 240addict Aerodynamics 29 01-22-2011 07:30 PM
2003 toyota camry baby blue and not a scratch. weatherguy Introductions 2 01-11-2009 06:02 PM
CNG camry Hybrid, LOVE the aero look rav Aerodynamics 6 11-24-2008 02:15 PM
Toyota concept aero truck LUVMY02CREW The Lounge 14 11-14-2008 12:16 PM
Pics of my aero tweaks on 2000 Camry OfficeLinebacker Aerodynamics 14 04-22-2008 10:34 PM
