Old 08-04-2010, 11:01 PM   #1 (permalink)
Lil Sulf - '94 Corolla
90 day: 47.62 mpg (US)
Toyota Corolla, boat tail
So I'm making a partial boat tail for my 1994 Corolla. I haven't really been home all summer and now that I am, I've decided to try some "improvements". Unfortunately I can't do any scientific testing because I have no way to read instant mpg. Anyway, I have some flat, bendable metal strips and plexiglass and/or polycarbonate pieces that I have drilled and fashioned into a partial boat tail. It is connected at 3 points on top of the trunk, 3 points underneath the car (below the trunk), and 2 points on the bumper that reinforce the outside bottom 2 supports. I will be adding more soon: some aluminum to the sides, connecting to the "tail".
The sloping angle isn't as gradual as the ideal teardrop shape I would like, but it is certainly an improvement over the drag my car would create without any modifications.
I will try to add pictures when it's finished.
I'm averaging 45-50mpg, depending on how fast I drive - if I can consistently average 50+ than I will (almost) know that it is working).
And that's without a Scangauge o.O
Old 08-05-2010, 06:40 AM   #2 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
Sounds interesting, have you gotten any comments from other drivers?
Nissan Versa Aeromods
Old 08-05-2010, 05:31 PM   #3 (permalink)
I've gotten a lot ok looks today - probably 5x as much as when I added my rear wheel skirts, though it could be a combination of having both . . .
Old 08-05-2010, 09:02 PM   #4 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Can you post some pictures, please?
Old 08-05-2010, 10:50 PM   #5 (permalink)
Maybe tomorrow. Bug me if I don't
Old 08-06-2010, 02:05 PM   #6 (permalink)
Added pictures, though they look like a red x to me. Hopefully its just me. If you cant see them, look at my garage pictures.
Old 08-06-2010, 03:09 PM   #7 (permalink)
Tenderfoot
ChazInMT's Avatar
MagMetalCivic - '04 Civic EX
90 day: 37.18 mpg (US)
Great Job! Hope it works well for you. Tons of work into I'm sure!
The Following User Says Thank You to ChazInMT For This Useful Post:
Sulfuric (08-07-2010)
Old 08-06-2010, 03:55 PM   #8 (permalink)
skyl4rk's Avatar
So can you tell if it is helping? Maybe try a coastdown time test in neutral from 60mph to 40mph, comparing tail with no tail. Of course you would have to take it off to do that.
Old 08-06-2010, 04:06 PM   #9 (permalink)
Well, it seems like I can coast just a little bit further. I have a road of about ~1 mile between lights, and I used to be able to get to almost 50mph, and then coast to the light and be at about 30ish before I would go through it or have to brake. I did the same thing today, and I was still at almost 40mph at the light, but it could be some other variable like a tail wind or maybe I started closer than usual.
I think it is helping but it could be the placebo effect.
Also, I really don't want to do ABA testing. Not very scientific, I know, but it was rather hard to get the screws in that connect the bottom part to the underside of the car. I did fashion it so the trunk is still able to be opened, though; you can see the wingnuts in the third picture. I just screw them off and it disconnects enough to open the trunk.
I think I'm going to add a little bit more, to have the tail become more of a point.
Edit: I also have a question. I found some 14 hubcaps on craigslist, but they are to a 70s chevy nova . . . do you think they would fit? I have 14 wheels but I'm not sure if all "same" sizes are really the same.
Old 08-06-2010, 11:59 PM   #10 (permalink)
I added another plexiglass or polycarbonate panel to the bottom. The air from underneath the car should now stay attached farther back, hopefully creating less drag.
I drove to a an outside beach movie tonight (just got bacK), and I think it coasts longer. I've been making .5+ mile glides much more frequently now and sure seems like I keep my speed longer. That gradual "slowing down feeling" (negative g force?) is much smaller.
Pictures tomorrow, maybe. I might even add more.
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 10:30 PM
1995 Toyota Corolla II - AWD matty For Sale 0 02-17-2010 08:20 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 7 05-30-2008 11:23 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 09:02 AM
