Old 02-28-2009, 12:42 AM   #11 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 17.6 mpg (US)
Heep - '011 Grand cherokee Larado x 4x4
90 day: 19.92 mpg (US)
Old toy - '81 Cm400e
Da bike - '06 Shadow Vlx deluxe
90 day: 50.2 mpg (US)
my guess is secondary runners that open at load?
my wifes old 2000 v6 cougar had that, but at 30k on the clock they woud get stuck and the car would hesitate like something awful. actully the car was awful, great areo, decent(ok knda low) power for a v6 (170hp), relaibily sucked warped flex plate was awful on everyone of those cars.
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 02-28-2009, 09:22 AM   #12 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Yeah, thats pretty much it Taco. Here is a pic of a Toyota ACIS manifold off an older engine. In the second picture you can see they use a vacuum actuator to open the butterflies on the secondary runners. When vacuum is low in the intake manifold plenum, the actuator opens up and opens up the secondary runners. To prevent this from happening at too low an rpm (not enough airflow to make the secondary runners worth opening), they use a vacuum solenoid valve. Below X rpm the solenoid stays shut and the actuator can never see low vacuum pressure. Its actually a pretty simple setup.
