Originally Posted by botsapper
There is that H-pattern shifter knob, it is an automatic but you could use the shift knob to ghost-clutch shift gears in manual mode without the need of a clutch pedal.
Sounds interesting. But is it really automatic, or some sort of AMT similar to the one fitted to some Toyota and Hino hybrid trucks, resorting to the Power Split Device to compensate for the lack of an actual clutch?
