Old 08-25-2008, 01:19 AM   #21 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by instarx View Post
I grew up in a trucking family...
I have always thought that a bunch of "truck-trains" would make sense. Trucks with tractors would be driven onto a train, the drivers would retire to the lounge/sleeping car to travel in comfort to a hub near their final destination. The trucks would then be driven off the train and head for the factory docks.
Consequently, I grew up in a Railroad family. I can say that the influential Intermodal depots would instigate a "payload only" initiative. Plus there's safety and emergency concerns. Changing a railroad's operating procedure happens every 25 years or more.
Norfolk Southern had a neat idea with the "Triple Crown" or "Roadrailer" service several years ago (still in operation on a limited basis and with Amtrak). The trailer has the ability to attach railroad trucks between the rear axles or at other attachment points, and be shipped using maritime operations (3 modes):
In the meantime, many point-to-point, LTL, and the vast majority of intermodal services will rely on truckers to do the runs.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 08-25-2008, 01:25 AM   #22 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Like this...
Small truck versions hard and inflated
credit to aerohead gallery!
Concrete
Start where you are - Use what you have - Do what you can.
Old 12-26-2011, 09:45 PM   #23 (permalink)
Originally Posted by trikkonceptz View Post
What's sad is I was researching this to see if I am re-inventing the wheel here and all I found was a company that got money to build what they called a boat tail ... Try not to cry to hard; Ken Visser Research Page
The sad news is they saw a positive change with something so primitive. But in my opinion is so wrong on so many levels.
Well, I think this automated inflatable boat tail design is a whole lot better. There is no requirement for the driver to do anything. It automatically deploys at highway speeds. Then it stows before arriving at the dock. Its called the SmartTail by ATS. ATS Aerodynamic Trailer Systems - SmartTail and WindTamer products to reduce aerodynamic drag
Old 12-27-2011, 06:19 PM   #24 (permalink)
Lightbulb Smart
Maybe it will make a go of it in the market.
With nothing more than a cruise control logic and a potentiometer to adjust set-points,the driver shouldn't have to be bothered by it.I came up with a simple reversing valve which allows the inflation fan to do the evacuation of the
envelope.
If they would allow the lower portion to be 'bagged',they could do away with a lot of dangerous splash and spray along with additional drag reduction.
Steven Chu might dictate terms to D.O.T. and ask for resignations from anyone who doesn't want to play ball.
Kammbacks & tail aero info Bearleener Aerodynamics 30 07-22-2010 06:56 PM
Trailer Hitch Boat Tail? superchow EcoModding Central 16 04-26-2010 02:35 PM
Diffuser VS Boat tail Vince-HX Aerodynamics 14 09-03-2008 11:56 AM
Rear Wheel Boat Tail Fabrication 2003protege Aerodynamics 1 07-24-2008 05:16 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 7 05-30-2008 11:23 PM
