Old 09-08-2008, 04:47 AM   #1 (permalink)
Traffic Jam is Killing my MPG
The KM reading from my home to work is just 15km translating to 9.32 Miles and imagine that it takes me an hour and 15 minutes to get there. So you can imagine the traffic that I am facing everyday. Ultimately wasting gas. I drive a Honda civic 05 4 door sedan. I guess its not my driving style since I am so conscious nowadays.
The only modifications that I have are these:
17 inch magwheels (might add to the weight- not sure with my tire specs)
Subs at the back of my trunk(might add to the weight)
Royal Purple (10w40 should I go thinner?)
Any inputs guys? Is there hope?
Old 09-08-2008, 04:58 AM   #2 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
Some hope but if its as jammed as it sounds, no mods will really matter other than finding a different route that isn't so congested. Other option include:
DRIVING
> creating a larger front buffer gap in front of you
> neutral coast when possible (easier if you have that gap)
> neutral idle if you must idle
> engine off if nobody is moving
> turn off all unnecessary accessories (A/C, radio, coffee maker, etc)
> look into alternative route
TIRES
> make sure the tires are pressured up
> opt for low rolling resistance tires
> look into lighter wheels
WEIGHT
> put your car on a diet
> put yourself on a diet
ENGINE
> go as thin as you can but make sure your car can handle it. Some recommend synthetic or 0w but I have no experience with that.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 09-08-2008, 05:54 AM   #3 (permalink)
Thanks bro for the reply. I have further questions:
For driving here are my questions:
they say that in neutral driving, the air-fuel mixture is 1:1 as compared to geared, the ratio is lower in favor of the air. since the ECU thinks that you are going to do an engine break. how true is this?
For tires can you suggest a specific magwheel combined with a specific tire with low resistance rolling?
Old 09-08-2008, 06:12 AM   #4 (permalink)
Tracy - '00 corsa
go hybrid mod !
or for the lazy mod try the big battery mod. power for ignition is 17% of fuel costs at low speeds. if lights are on in traffic jam its even more. Alternator Delete VS starter motor
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 09-08-2008, 07:41 AM   #5 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
15K? Ride a bike! 1/2 of a pint of lube / year-- How's that for fuel efficient?
Old 09-08-2008, 10:49 AM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I would try a bike, you'll save a lot of gas and about 45 minutes,
Old 09-08-2008, 03:19 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
gasti_ako -
This doesn't sound right, but I may not understand your question. Under normal driving conditions in the USA, the Air/Fuel ratio is 14.7 parts air to 1 part fuel (14.7:1). The car's ECU tries to maintain this Air/Fuel ratio most of the time. Running "lean" means increasing the amount of air. For example, a lean ratio could be 16:1. Running "rich" means decreasing the amount or air. For example, a rich ratio would be 13:1.
Many newer cars will run lean "by design" when the car is decelerating in gear. Some cars will cut off the fuel completely until the car's normal "idle RPM" is reached.
All cars will run rich when the driver is driving for performance.
The 14.7:1 ratio is used because the emission standards in the USA require this ratio. Otherwise, the catalytic converter won't function properly.
What are the emissions rules in the Philippines? Do you have a catalytic converter on your car?
I agree that a bicycle/scooter/motorcycle would be better, but I also think you get a lot of rain, so it isn't practical for work. Can you commute with a coworker?
CarloSW2
American Solar Energy Society
Old 09-08-2008, 03:25 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
gasti_ako -
Here is a great thread on how the air/fuel ratio works with emissions :
AutoSpeed on running lean for fuel economy
Here's the article the thread is pointing to :
Autospeed - Running Lean for Economy
It’s self-evident: the less fuel you burn with each kilogram of air, the better the fuel economy you’ll get. Therefore, if you can reduce the amount of fuel going into the engine and still travel at the same speed, you’ll reduce fuel consumption.
So why doesn’t everyone reduce the intake of fuel? The answer to that is more complex than it first appears.
CarloSW2
Old 09-08-2008, 04:48 PM   #9 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '010 Agility 125
Unless you're up to building a battery-powered pusher trailer, I'd go with the bike recommendation as well. If you're worried about pedaling yourself sweaty, there are a few nice electric bikes out there on the market that will allow you to pedal very little at the beginning, and then more later as you get into better shape.
Old 09-09-2008, 12:40 AM   #10 (permalink)
Originally Posted by cfg83 View Post
gasti_ako -
CarloSW2
thank you for the well thought reply. I just wanna make sure that Neutral Driving/Coasting is ok.
I am also agreeing with you with alternative modes of transportation, in fact I take the train most of the time. My car has been a weekend car so to speak.
I just want to make sure as well that its the traffic and not the car or driver which/who are the source of low MPG. When I went highway driving, I got 33 MPG. Though I am quite speeding at around 60 M/hr. So I am thinking that my highway driving MPG could have been better.
In addition, i think my wheels being a 17" is also a factor. That is why I am changing it when its time to change my tires.
40 mpg last night wagonman76 Success Stories 7 03-11-2012 03:12 PM
Idea for government: Traffic Light Timers newtonsfirstlaw General Efficiency Discussion 29 03-10-2012 11:33 AM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
Traffic experiments: a cure for waves and jams (improves other people's MPG too) MetroMPG Hypermiling / EcoDriver's Ed 13 01-20-2008 09:35 PM
