Old 02-23-2012, 08:27 PM   #21 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
My two bits says make the front fill in as much of the space/volume between the tailer and the truck as posible. the tail end of the trailer looks great.
Old 02-23-2012, 09:02 PM   #22 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
^^ I agree with yaris. You could gain a few "free" feet too.
The template is not placed correctly. The "ground" in the drawing should line up with the "ground" in real life. Correct that and it will look great!
Good luck on the build.
Old 02-23-2012, 11:05 PM   #23 (permalink)
90 day: 19.36 mpg (US)
Tractor-Trailer gap is ideal at 24" or less. Above 30" is frowned upon.
Looks like fun, Ed. What "accommodations" will this trailer feature. That might help what-to-put-where and point a particular direction.
Have you a floorplan in mind? Or, interior wall-plan? I've seen some good give-and-take on AIR around these questions (exterior shape is given, but interior plans can go a very long way to using space).
Old 02-24-2012, 08:38 AM   #24 (permalink)
Ed-in-Maine's Avatar
Iceberg - '02 Ford F250 XLT
Pickups
90 day: 18.3 mpg (US)
Tool - '08 Toyota Matrix XR
90 day: 43.15 mpg (US)
slowmover-Not much to a floor plan in a 4'x11' area But yeah, the bed is forward the rear is a "chuck wagon" type area. I think I'll make the rear hinge up to an awning position to give my wife coverage when at the camp stove.
But with this extra volume dictated by aero considerations I'm thinking about a "garage" area for a bike(actually a "Catrike Trail"). I'm riding a Trident ST2 Trike from Maine to Washington state this spring/summer. My wife will SAG for me. We have tent camped always in the past but 90+ days of tenting is a little extreme for us. So this little trailer is just one step up from tent, but without all the fiddling that a standard Pop-up requires.
Ed
Name:	Teardrop HF 1947 side.jpg
The Following User Says Thank You to Ed-in-Maine For This Useful Post:
Sven7 (02-24-2012)
Old 02-24-2012, 08:48 AM   #25 (permalink)
Pickups
Here is the newest top view. I can't upload too much on a single post.
Ed
Name:	Teardrop HF 1947 top.jpg
Old 02-24-2012, 09:40 AM   #26 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Ed, I would make any nice aero shape you want so long as there are a minimum 2' tall straight sides on it, and then make it a two piece slider or pop-up. I have several ideas regarding hard sided pop-ups. No fiddling, no tent section, just slide it up or down in a hurry.
Stand up = momma happy
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 02-24-2012, 09:45 AM   #27 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Ed, those HF kit trailers are 4' wide, right? If you build the deck wider with wheel wells and skirts then you could increase the beam to match the tow vehicle (somewhere between 5 and 6 feet). Without any elbow room on the sides of the mattress you'd probably have to crawl over it. If offset to one side there might be enough isle to get past it. Think about where you want the door (assuming only one) how big it can/must be. That will constrain body geometry. Then I'd use the template to maximize interior space with least aero penalty.
More food for thought:
1. Airstream Basecamp
2. Frankenhauler: web page forum thread
3. Tiny toy hauler (Scamp hack): blog post
Recreation Engineer
Old 02-24-2012, 10:46 AM   #28 (permalink)
Pickups
skyking- I would love to see those popup designs you have, don't know if I have the build time but it would be very interesting. Can you email them or post. Dry Bed that doesn't rock == momma happy We lived on sailboats for 5 years and my wifes first question is always "how are you going to keep the rain out". Also what's that plane in your avatar? Love the old war birds
Kamperbob,-yes HF base is 4'x8', I've been thinking of widening to tire width but it's not giving much more utility. The design has a his/her door on each side. But craw over isn't that bad, had to do it on our last two boats.
That Airstream looks sharp but I was glad to be sitting down when I saw some used prices OMG Also weight becomes an issue. I have an uncle towing a Scamp 13' with a Matrix, IMHO he's nuts. I want to keep empty trailer weight under 600lbs, loaded for highway 1000lbs.
Old 02-24-2012, 05:59 PM   #29 (permalink)
plan taper
Ed
I know that you'd lose interior space,but allowing body plan taper would give upwards of an additional 38% drag reduction.Both Walter E.Lay and Wunibald Kamm confirmed this during wind tunnel research.
The gap is hurting you also.If the gap must remain,then a bulbous nose will give the lowest drag,especially in crosswinds.
If you can look at Hucho's books,you'll find hard numbers attached to different trailer architectures at varying degrees of yaw.
Old 02-24-2012, 07:24 PM   #30 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
