Old 12-01-2010, 11:25 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Trailer tires on truck?
I found some almost new, hardly used goodyear marathons at work that are the right size. They are $10 a piece. I have read a bit about other people using trailer tires on passenger vehicles and would like to get a general opinion on using these. They are E range 235 80 or 85 16, I can't remember. They look good, but I don't know if they are the "circle S" ones. They will be used for drives until I can afford proper tires. Thoughts please.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 12-02-2010, 01:17 PM   #2 (permalink)
Tire Geek
CapriRacer's Avatar
This is a terrible idea:
1) Trailer tires are speed restricted to 65 mph compared to regular LT tires which carry at least a 99 mph rating and sometimes a 112 mph rating. This means they are built to lower standards.
2) Trailer tires have to meet lower government standards than LT type tires.
3) Tire manufacturers built trailer tires with the idea that there is a decreased risk of someone getting hurt if one fails. Plus there isn't any real need to worry about traction and handling - or even treadwear.
4) The tires on your truck are 85 series, while the trailer tires you mentioned are 80 series, which means the trailer tires are smaller - another thing in wrong direction.
5) The last thing is not so technical: You have to wonder if someone took off a set of tires, why did they do that?
The Following User Says Thank You to CapriRacer For This Useful Post:
Cobb (03-26-2014)
Old 12-02-2010, 05:07 PM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Trailer tires are not designed for traction and we are going in to winter, they are instead designed for heavy loads and are built much thicker so they tend to have a pressure rating of 65-100 psi.
Old 12-03-2010, 09:54 AM   #4 (permalink)
90 day: 19.36 mpg (US)
Forget this. ST tires are just about good enough to be placed on a heavy trailer that sits for months at a time. Their ratings (have no standard speed rating; only a few can handle above 65 mph) are suspect in the first place. You'll find thousands of posts on RV sites complaining about them in general. And even if they are correctly load-matched to the trailer they are not at all suitable otherwise for cars/trucks. This is a bad idea. I'd go to Craigslist or another source for take-off's to fit the vehicle. Find one set of four, or two sets of two, of LT tires.
Old 12-03-2010, 11:45 AM   #5 (permalink)
93 Geo Metro
Sippy - '93 Geo Metro Convertible
90 day: 43.8 mpg (US)
If you do it, make sure you use a camcorder so we can post the wreck on youtube <G>.
1993 Geo Metro - "Sippy"
Economy cam, +10 cam gear, 3.85:1 ratio
http://www.lightweightmiata.com/geo/
Old 12-08-2010, 09:48 AM   #6 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
IIRC, my 1998 HitchHiker 5th wheel had regular "E" tires on them, non-ST. I actually used my F250 spare tire/wheel which fit perfect when I had a flat. I bought all new tires for it 235/85/16E. You about can't get ST tires for big 5th wheels these days.
In a pinch, I suppose you could temporarily use trailer tires, but only if you treated them like 55 mph donut spares. On the contrary though lots of people drive their 5th wheels with ST tires at 75 mph, take the turns like sports cars and never have a problem. Usually the STs have pretty stiff sidewalls, so handling would be a touch "funny". Tread patterns on trailer tires vary so much these days they almost look like all-terrains. Overall, tough call.
Old 12-09-2010, 11:12 PM   #7 (permalink)
Team Pontiac
I am going to put them on in the morning. I was going to do it tonight but ran out of time. I will let you know how they work.
1991 F-250:
Old 12-10-2010, 04:02 AM   #8 (permalink)
EcoModding Jack
nimblemotors's Avatar
trailer tires are designed with stiff sidewalls that keep the wheels going straight as they are designed to do for a trailer. They would be a very bad choice for the front wheels that turn and have sideloads (which is why they make radial tires), but for the back wheels of a truck, might be ok, the quality issue notwithstanding.
Old 12-10-2010, 11:07 AM   #9 (permalink)
I love this
Are trailer tires a good idea? Then after everything everyone has said...
That's great. This post has made my week!
Old 12-10-2010, 09:04 PM   #10 (permalink)
Team Pontiac
That's funny right there! I had already pretty much made up my mind before I asked the question. I was looking for a general consensus to help me decide. It is a farm truck so I am not worried too much about ride quality, or handling. It rides like a tank either way. I just need something better than what is on there now.
1991 F-250:
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
HYPERMILING & TOWING: A Misconception slowmover Hypermiling / EcoDriver's Ed 27 12-14-2011 07:20 AM
I build a 4x4 Gas-Electric-Hydraulic Hybrid! bennelson Hybrids 5 02-10-2010 12:53 PM
