Old 07-17-2010, 07:17 PM   #1 (permalink)
whitey - '01 explorer sport 2door
Smile trailer towing
I have a 2001 ford explorer sport 2 door, and a transhual 6x10 cargo trailer which I uses to haul my flea market goods in. I found that towing the trailer drops my gas greatly, from 23 to 17-18 mpg.
Stock engine non mods, looking at aerodynamic changes to improve the milage appreciate any tips or ideas.
Old 07-18-2010, 01:14 PM   #2 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Tundra 4WD xCab
Half Pint - '06 XT225
Maybe you could post some pix.
Cheers
KB
Old 07-18-2010, 04:31 PM   #3 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
Tires up to max PSI.
Slow down a little.
Old 07-20-2010, 10:49 PM   #4 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
Your mileage is already good. A 40% drop is fairly common as a rule of thumb. If those are IRS deductible miles, then all the better. A 25% drop over 300-miles would cost about $12. It's just overhead added to the cost of goods.
As to mileage, weigh the trailer empty and loaded. Same with truck. Be sure trailer has brakes per law on weight, and/or WD hitch properly set up. Have trailer axle aligned. Brakes/bearings services. Radial tires no more than 5 yrs old. Tire pressures -- all of them -- according to Pressure & Load Tables (+20% if you want, or no less than vehicle manf numbers). Etc. Ck truck for brakes, bearings, etc. Run along just under 60 mph on limited access roadways.
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
Old 07-21-2010, 01:42 AM   #5 (permalink)
beamer - '91 318is
90 day: 32 mpg (US)
Not sure if yours is an enclosed trailer but I have an open 6x12 and I know
from experience there's but so much can be done, at least strictly speaking.
With my truck, straight up, the slower I drive, the better the mpg, plain and simple.
Fuel mileage once we get into weight has less to do with aerodynamics than
just getting it down the road, most of the engine's power simply goes to
PULLING the weight and although air does slow things down at higher speeds,
at 45 and below it's more having to counteract inertia than anything else.
Drive with load, go real light on the throttle, DWB's.
One thing that does help is keeping a minimum 6-8 seconds distance from the
vehicle in front, more so because it gives me time to let off the gas instead of
getting on the brakes, the more time I have to slow down, the better.
Unfortunately in traffic folks will cut you off constantly because of that space.
Ultimately if I know I may have to stop I may slow down a bit prematurely so I can coast into it, the idea being to avoid having to come to a complete stop.
Maybe we should call this Pre-braking
Predict lights, slow down when approaching any intersection also.
Heavy duty tires, definitely radials but I also run 6-ply rather than the standard 4's.
Beyond that things get pricey...
The ONLY thing I know of that definitely and greatly improves fuel mileage
is a full aluminum trailer, by full aluminum I mean the floor too as some
have wooden floors.
Unfortunately a full aluminum 6x12 open trailer new was $3000 several years ago.
There's another problem, few places sell them, and few places service them.
Old 07-21-2010, 09:57 AM   #6 (permalink)
Patrick's Avatar
Hot Tamale - '010 Prius III
You can try building a V-nose on the front using the tongue as a base. Maybe use some plywood sheets? This will probably give you the biggest increase in milage.
Change to rounded fenders if yours are squarish.
Add smooth wheel covers.
Add wheel skirts.
Add fairings behind the fenders.
Make sure the trailer is horizontal when towing (as viewed from the side). If it's not, get a different drawbar that lifts or lowers the tongue until the trailer is horizontal.
Old 07-21-2010, 04:39 PM   #7 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
I'd argue a "V-tail" will give you a bigger improvement than a "V-nose".
And FYI, just as a point of comparison: Honda Ridgeline MPG vs speed graph: fuel economy with & without cargo trailer
As well, have you seen this thread? Big project-F250 pulling 20x8.5 enclosed trailer - Page 7 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (07-23-2010), ChazInMT (07-23-2010), KamperBob (07-22-2010)
Old 07-22-2010, 08:04 AM   #8 (permalink)
Recreation Engineer
KamperBob's Avatar
Darin, you add so much value by cross linking these posts. Thanks a bunch. I'm buying when we meet some day!
Cheers
KB
Old 07-22-2010, 08:49 PM   #9 (permalink)
Kamper, buy a winter fairing for your trailer, and also try to keep the car in overdrive. Feel free to get up to 15 mph or so in 1st gear, but immediately overdrive and keep RPMs low.
Full-boat-tail trailer with gap-fillers for Toyota T-100 pickup aerohead Aerodynamics 272 05-01-2012 07:15 PM
HYPERMILING & TOWING: A Misconception slowmover Hypermiling / EcoDriver's Ed 27 12-14-2011 07:20 AM
I build a 4x4 Gas-Electric-Hydraulic Hybrid! bennelson Hybrids 5 02-10-2010 12:53 PM
VW wagon EV with charging trailer...thoughts? ai4kk Hybrids 34 02-04-2010 02:14 AM
MetroMPG.com: Electric pusher trailer MetroMPG Fossil Fuel Free 12 03-25-2009 04:38 PM
