Old 09-26-2014, 05:16 PM   #1 (permalink)
Who am I?
24601's Avatar
Moby Dick - '00 Ford Crown Victoria Police Interceptor
Team Panther
90 day: 21.64 mpg (US)
Question Transmission and Gear Swap Thoughts ('00 Ford Crown Victoria)
Having a 4-speed automatic with a 3.55 ring and pinion have had me contemplating how to go about alternatives that would provide better fuel economy.
My first thought was to swap out the 3.55s for taller 2.73s but which would significantly lower my cruising RPM, but would also make the engine work that much harder off the line.
I'm worried it would trade better hwy mileage for potentially worse performance in the city. So, this got me to thinking about the possibility of swapping the gears in conjunction with a swap to a 5 speed manual.
I've put together a comparison of cruising speed RPMs between different setups and the total gearing ratios. (Current setup in red)
If I did a swapped to a 5-speed with 2.73s I would only lose about 8% of gearing in 1st with the differences between 2nd and 3rd being negligible. It would also further reduce cruising RPM in 5th gear.
To put in perspective, doing the 2.73 swap along would result in a 23% reduction in gearing.
Thoughts?
Project Moby Dick
Best Tank Avg: 26.6 mpg | 66.3% over EPA
Best Short Trip Avg: 29.5 mpg | 84.4% over EPA
Old 09-26-2014, 05:22 PM   #2 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
I would try to get the best highway mileage you can. You have a heavy car. mileage sucks in the city. make it better on the highway and just drive at highway speeds and don't stop moving. Keep it above 45 as much as possible.
Old 09-26-2014, 08:19 PM   #3 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Id swap the rear end first.
- Tony
Old 09-26-2014, 09:01 PM   #4 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Use as small of a tire as possible while staying in the laod range required. You will reduce the effective gearing and reduce the energy required to spin the wheels vy moving the weight closer to the axis of rotation.
Looks like 2.73's with the 5 speed would be perfect.
Old 09-27-2014, 06:01 AM   #5 (permalink)
For a definitive answer, you need a BSFC map.
Don't forget that with an auto. torque converter slip alters the effective gearing (lower) where it is occurring.
Old 09-27-2014, 06:19 AM   #6 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I think a vic with manual would be awesome in the first place, but just remember, you will lose your off the like performance.
Old 09-28-2014, 07:12 PM   #7 (permalink)
That would be good with a wide-ratio transmission out of a truck instead of a close-ratio out of a Mustang.
samwichse (10-01-2014)
Old 10-13-2014, 04:25 PM   #8 (permalink)
Who am I?
24601's Avatar
Team Panther
I've searched high and low on the web and came up empty handed.
Project Moby Dick
Old 10-13-2014, 04:45 PM   #9 (permalink)
grey panther - '02 Mercury Grand Marquis
Team Panther
90 day: 27.15 mpg (US)
My 2 cents, just change the rear end gear first. Your PI v8 has plenty of power for the city for an ecomodder. Stick with a taller tire, the beast needs lots of rubber on the road.
Old 10-15-2014, 09:10 PM   #10 (permalink)
adam728's Avatar
Mazda3 - '08 Mazda 3 S
90 day: 29.65 mpg (US)
DR650SE - '13 Suzuki DR650SE
90 day: 46.16 mpg (US)
Wife's - '12 GMC Terrain SLE-2
As said, going manual is going to lose the torque multiplication given by the torque converter off the line and when unlocked. 2.73's and a manual will be a chore every time you get rolling from a stop, lots of clutch finesse.
Not to mention - what's the cost and time to go to a manual? I know others have done it, but seems very involved to try and save gas. I would guess it would be very difficult to pull off for less than $1000, and lots of fabrication time. I'd definitely start with a rear gear swap. While still costly, it much more easily doable. I also would take some time to think about what speed you drive, what rpm the converter can lock in 4th gear (and under what loads). It wouldn't be a great thing to go to 2.73's and then find that load/rpm means the converter stays unlocked until 65 mph or something.
