Old 11-25-2008, 01:55 PM   #121 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
So approximating 2 yd's of 50" wide cloth per layer... Minimum of two layers (top and bottom).
17oz biaxial weighs about 47oz. taking 50/50 resin/cloth ratio (and assuming 1fl.oz. of resin = 1oz by weight - assumption from the supplier), that's 94oz per layer - 188oz for two layers... Which is ~11.75lb in cloth/resin.
Add the weight of foam and glue which I'm estimating ~ 5lb. that brings me up to 16.75lb. Slightly over budget on my weight goal at a cost of $34 in cloth plus shipping.
If I move down to 12oz cloth - that's a weight of ~8.33 lbs - plus ~5lb in foam/glue -> $13lb... Which is within my target of >15lbs at a cost of $33 in cloth plus shipping.
BUT, 12oz cloth is disproportionally more expensive.... I'm wondering if I should "go for broke" with the heavier stuff. I feel either of these weights will be more than strong enough because of the geometry I'm forcing, but I'm not entirely sure....
My decisions analysis says....
Foam Template/Core - Biaxial cloth - Epoxy Resin....
This weekend I'm home for thanksgiving, then it's the week before finals.... Then it's finals week.... Then I go home for a month.... I need to see what my finals load is this semester - if it's not too bad, I might start building late next week. Worst case, a few weeks.....
I've settled on 18.25 degree profile taper.... Now I'm looking for an optimal bird's eye taper. It's proving difficult because of the angles the rear of my car presents. A small lip spoiler and some styling should help it "fit in" with the rest of the car. I'll have a 3d model of the Kamm soon, but I've got a "test" of sorts to study for at the moment
Challenge me, or correct me, but don't ask me to die quietly.
Old 11-25-2008, 02:09 PM   #122 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
hence the reason I never build parts that have to be structural as a rule... I don't feel like figuring all that crap out, I just like brushing on the resin!
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 11-25-2008, 02:25 PM   #123 (permalink)
MechE
Nah, this isn't structural It just needs to hold it's shape.... Well, I guess it needs to support a small amount of load where it hinges - but that's about it
Old 11-25-2008, 02:27 PM   #124 (permalink)
Oh, in your weight analysis, did you count the moulded in mounting locations, etc.?
I would assume a nice delrin composite flange moulded between the two layers would be sufficient.
Old 11-25-2008, 02:45 PM   #125 (permalink)
MechE
Nope - I didn't include the weight loss from the windshield cutout plus the weight of the windshield itself.... I don't know what I'm doing for that just yet, so I can't speculate. Not 100% on the hinge part either, I need to mock up things first.
Old 11-25-2008, 02:49 PM   #126 (permalink)
Just for kicks, you should run a quickie of the kamm with a 2 or 3* upturn not more than 3 inches out.
Old 11-25-2008, 06:42 PM   #127 (permalink)
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
I was looking at the "unique spoiler", and if you said with cfd it showed a net gain of about 2%... I wonder how much better (if any) it would do if there was a second spoiler inverted and added to the bottom bumper. The lift/downforce would offset each other, so you could shape the lower one different to keep the downforce if that's desired. Either way, you might be in the 4 or 5% gain area. In practice, these could be added to the sides of the car also to help just a little more (unless they blocked the brake lights too much). Something to think about.
Old 11-25-2008, 07:44 PM   #128 (permalink)
I think I understand what you're saying, wyatt, but would really like to see some kind of sketch or something to make sure that I fully understand.
Old 11-25-2008, 08:20 PM   #129 (permalink)
Suzi - '94 Swift GA
I'll see if I can make one tomorrow... But you probably have it pretty well figured out.
Old 11-25-2008, 10:28 PM   #130 (permalink)
I think I do, I just want to physically see that what's in my mind is what's on yours. It's better for me (And several others) to verify an idea by seeing it.
2009 VW Jetta TDi Fuel Economy Review: 41.1 MPG SVOboy EcoModder Blog Discussion 3 12-19-2009 04:37 PM
Possible buy '85 VW Jetta TDiesel Taco Bowl Introductions 3 11-19-2009 11:00 AM
AS SEEN ON TV! 2001 VW Jetta TDI Diesel Greasecar WVO gblau For Sale 0 10-28-2009 10:44 AM
LA Auto Show: VW Jetta and Racing World Premiere SVOboy EcoModding Central 0 11-21-2008 04:12 PM
Is VW lying to the EPA? Why does Jetta sedan / wagon have identical MPG ratings? MetroMPG General Efficiency Discussion 16 11-07-2008 05:39 PM
