Old 11-14-2008, 09:05 PM   #31 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Are you using that photo to get the Prius lines? I think there's some lens distortion in that one that exaggerates the roof angle.
Old 11-14-2008, 10:24 PM   #32 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
So, as of yet, I have not modeled directly against the Prius....
The last cross section I posted was a simple line, from the trailing edge of my trunk to the first tangent point on my roof line. I'm thinking, if I go this route - that'd be the way to manufacture it - because I'll need a false windshield and I'm ill equipped to make optical compound curved plastics...
I'd have CFD for you, but I accidentally killed the power to my laptop before going grocery shopping - my laptop died mid calculation
How's this picture?
Challenge me, or correct me, but don't ask me to die quietly.
Old 11-14-2008, 11:00 PM   #33 (permalink)
Silver Turtle - '02 Focus Zx3
90 day: 38.83 mpg (US)
Originally Posted by Deezler View Post
p.s. I plan on mounting VGs on the roof, just for fun.
I have them on my Mazda 6, and as far as I know nobody with a Mazda 6 (4cyl Auto) has been able to hit the mpg figures that I have been hitting...
Today new high of 42mpg with winter blend gas and 75 degrees outside...
I DO attribute Vg's to some of that success; here is testing I did on them-
--- "vortekz" Generators Tested!! --- Pictures!! - GasSavers.org - Helping You Save at the Pump
Old 11-14-2008, 11:38 PM   #34 (permalink)
I think this one's better: http://www.crunchgear.com/wp-content...yota_prius.jpg
I measure a 9% angle (from horiz.) from the highest point of the roof to the end of the spoiler in that pic, vs. 10% for the silver car and 13% for the red car (after correcting to make the wheels level)
Old 11-15-2008, 01:25 AM   #35 (permalink)
MechE
Thanks Metro - I'll work on that shortly...
I've been going back and forth between the cut plots (what I've been posting) and working on the 3D model... The 3Dmodel is HUGE, and really bogs down my machine... Saving is a 5 minute operation, and I've already crashed once I've got maybe 100 or so features to repair - even then, I don't know if it will work
Boundary layer pictures
Those points (some highlighted) indicate where the boundary layer WAS in my last boundary layer post - this shows improvement Angle, according to SW, is 18.18 degrees... As before, red=55mph or more, blue=0mph or less
Here's the wave plot, just to keep things organized
Metro, where are you measuring the 9 degree angle? I'm getting ~15 degrees
When I measure from tip of spoiler to very top, I get something ~9 degrees....
Old 11-15-2008, 01:45 AM   #36 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
For a first guess, I start with the maximum angle at any area on the back of 15 deg. On the bottom, where air can't flow in from below, I start around 5 degrees, depending on several factors.
Old 11-15-2008, 02:27 AM   #37 (permalink)
Greta - '00 Jetta TDI
90 day: 59.96 mpg (US)
Send a message via Skype™ to ChrstphrR
Since Cd got you that model via my original digging ... I'm just curious now, trebuchet03 ... what format is that model saved as -now-?
Maybe I can help and do some of the trimming down on the model to help you cut down the size of it, so it won't bog your machine so. No ulterior motives for me, being that I get direct benefit from ANY work on Jetta models you get good results with, after all.
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
Old 11-15-2008, 06:19 AM   #38 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
you may want to have a look at The-Blueprints.com - 25990 blueprints online
not all drawings are in hi res but most cars have several drawings wich should allow you to extrapolate certain angles rather accurate... even the low res sketches can be of use if you import them into a vector drawing softwae (like the free package inkscape) and draw a curve anong the pixeled edges.... wich you can tha scale and overlay on a different drawing
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 11-15-2008, 06:23 AM   #39 (permalink)
Interested Newbie
Katana's Avatar
Silver Citroen Saxo - '02 Saxo 1.4i Furio
Cool stuff but not sure i understand the images, the different colours represent different air speeds, if so which colour is "best", do you want the air moving quickly over the surfaces?
Would be cool to see one done with a teardrop shape showing how a "perfect" aerodynamic shape looks in the program.
Crooked toothed, tea swilling crumpet eater!
Old 11-15-2008, 11:37 AM   #40 (permalink)
MechE
Originally Posted by tasdrouille View Post
This thread is really interesting. Care to give a quick shot at just a small 45 degrees lip spoiler that would be as high as the boundary layer is thick (edit: on the baseline model) at the rear edge of the trunk?
Setup
I modeled with the cut plot visible, but I turned the plot off so you could see the result.
The next two wave plots show velocites from 0-55mph - anything above is saturated black. This makes seeing the BL and separation zone much easier.
Baseline
45 degree Result
Separation happens earlier... Intuitively, this makes sense.
2009 VW Jetta TDi Fuel Economy Review: 41.1 MPG SVOboy EcoModder Blog Discussion 3 12-19-2009 04:37 PM
Possible buy '85 VW Jetta TDiesel Taco Bowl Introductions 3 11-19-2009 11:00 AM
AS SEEN ON TV! 2001 VW Jetta TDI Diesel Greasecar WVO gblau For Sale 0 10-28-2009 10:44 AM
LA Auto Show: VW Jetta and Racing World Premiere SVOboy EcoModding Central 0 11-21-2008 04:12 PM
Is VW lying to the EPA? Why does Jetta sedan / wagon have identical MPG ratings? MetroMPG General Efficiency Discussion 16 11-07-2008 05:39 PM
