Old 11-12-2011, 03:53 PM   #1 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Ram 2500 ST Quad Cab 2wd, short bed
90 day: 33.32 mpg (US)
Trouble code from too good mileage?
So my check engine light has been on for a while now. I checked it when it first came on and found it was my exhaust manifold pressure sensor. I found out the pressure tube was plugged up with soot (common problem for my engine), but didn't have the 27mm deep well socket to take out the sensor and fix it until today.
So anyway, I took out the sensor, cleaned out the tube and then hooked up my diagnostic reader to delete the trouble code. When I did that I found out that I had 2 trouble codes, the original one for the pressure sensor and this one:
P0461 Fuel Level Sensor 1 Performance / Rationality
I watch my fuel gauge like a hawk and I know for certain that it's working just fine. While I'm not certain, the only thing I can figure is that the ECM just can't figure out how the truck could possibly go that many miles without the fuel level moving very much.
I think I should be proud of myself
Diesel Dave
~Life is an optimization problem.~
~Who says that just because your vehicle weighs over 3 tons that you can't get good mileage?~
Old 11-12-2011, 04:58 PM   #2 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
Old 11-12-2011, 07:36 PM   #3 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
That's easy to fix, you just drill a small hole in the fuel tank - but put a cork in the hole while you're parked.
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
Old 11-12-2011, 09:24 PM   #4 (permalink)
JRMichler's Avatar
Nameless - '06 Canyon
90 day: 33.19 mpg (US)
Don't know if your P0461 is the same as my P0461, but I get a P0461 code just about every first EOC after filling the tank. Usually the gas gauge goes to zero at the same time, and stays there until I cancel the code.
I also get a low fuel alarm (3 chimes and a message) at bump start after an EOC more than about 0.6 miles. The gas gauge will drop to zero, then back to where it belongs. It normally does this without setting a trouble code.
Old 11-13-2011, 07:05 PM   #5 (permalink)
The fuel gauge hasn't been doing anything unusual for me. I have been doing just a tiny bit of EOC recently, but pretty much only when I'm coming to the end of my trip. I guess that could be throwing it (miles with no gallons, so to speak). Personally, I wonder wheter it might be the fact that I generally run the tank down fairly low before filling up (replying more on the in-cab display for miles to empty, than the fuel gauge itself). This last time I stretched it a little more than I normally do the last few times. The gauge itself was on E for quite a few miles. That might have thrown it--again, lots of miles with no detectable gallons (according to the fuel gauge).
I'm not really concerned or anything--just amused.
Diesel Dave
Old 11-13-2011, 09:18 PM   #6 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
The idea as to why is funny, no question. After a weekend of wrenching on the XJ -- with different codes coming up -- I'll also hope things are as you say they are.
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
