Old 09-24-2011, 06:50 PM   #1 (permalink)
Whitey - '010 Ranger XL
Pickups
90 day: 29.44 mpg (US)
Wife's - '010 Clubman
90 day: 36.08 mpg (US)
Trucks- cab/bed sealer
So I was walking around Lowe's after my wife's break from work today and inspiration hit me! I saw a Replacement Gasket Kit for stoves, fireplaces and furnaces. The package actually says "prevents air leaks, Improves efficiency" in bold letters. It contains a braided rope and gasket cement. The sizes I saw were 3/8" and 5/8". I went and measured my Ranger: top gap is 1", side gaps are 1 1/2" and the underside is 2".
Provided I can find the appropriate braided ropes, does anybody see a problem with this aero-mod?
Check out my facebook page, if you feel like watching my progress.
http://www.facebook.com/pages/MPGran...007268?sk=wall
Old 09-24-2011, 11:02 PM   #2 (permalink)
idk. try it see if it works. also purchase some goof off in case it doesnt...
edison invented the light bulb after 1000 tries.
Old 09-24-2011, 11:29 PM   #3 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Hmmm,
Haven't seen it with gasket cement before. You mean like Permatex / form-a-gasket ?
The old stuff with retort cement would harden and crack, then fall out from the vehicles vibration.
With a flexible cement, it might work but would be tough to get to look good.
You don't need the fire retardant rope. Try 2" backer rod with smaller ones then regular urethane caulk.
That's how gaps are filled in concrete walls and it lasts many years.
And urethane caulk is paintable.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 09-25-2011, 04:10 PM   #4 (permalink)
JRMichler's Avatar
Nameless - '06 Canyon
90 day: 33.19 mpg (US)
Be careful. There is a lot of movement between the cab and the box in a pickup truck. I believe that other aero mods will have much larger benefit. But if you really want to seal that gap, I've seen a foam gasket about 2 inches square in the hardware store. It's designed for air conditioners or something. Bond it to either the cab or the box and let the other side slip.
The Following User Says Thank You to JRMichler For This Useful Post:
d3vi1d06 (09-26-2011)
Old 09-25-2011, 08:41 PM   #5 (permalink)
sid
grayranger - '010 Ranger XL 2 door supercab
90 day: 31.09 mpg (US)
I use foam pipe insulation. I feel the foam rubber type seals better than the flexible plastic foam. But it requires a lip on your topper, which all my toppers have had, to keep the foam in place.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
Old 09-25-2011, 11:20 PM   #6 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
I believe this is the stuff that JRMichler is talking about:
You can use silicone caulking to keep it in place and even double it up where needed.
I've used it for sealing up gaps between structures before and smaller versions for ecomodding purposes on cars. It holds up to weather very well.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
The Following User Says Thank You to TomO For This Useful Post:
Old 09-26-2011, 09:42 AM   #7 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Why not just use a bicycle inner tube? cut it into a straight tube if it's not otherwise large enough and seal off the ends, inflate it just a little so you can stuff it in place then inflate it more so it expands enough to firm up.
To cap the ends use rubber cement, jar lids and wrap it in thread to keep it from coming apart.
Old 11-04-2011, 07:48 PM   #8 (permalink)
How much of a difference does it make to fill in the cab-bed gap?
Old 11-04-2011, 10:54 PM   #9 (permalink)
Kodak's Avatar
Canyon - '07 Canyon 2wd regular cab
90 day: 24.83 mpg (US)
I second using a flexible, forgiving material over a hard one.
EcoDriving: Turning more fuel into usable forward motion.
Old 11-14-2011, 03:28 AM   #10 (permalink)
EcoModding spendthrift
WindedWarrior - '012 Focus SE
90 day: 33.46 mpg (US)
Back in 1999 I had a single cab f150 and a camper on back. I used an inner tube to seal the camper to the open cab window. This is a great idea and I bet it works better than the gasket you've sourced.
"May the wind always be at your back and the sun always upon your face. May the wings of destiny carry you aloft to dance with the stars."
~ Boston George
