Old 12-04-2009, 08:04 PM   #11 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
Originally Posted by thatguitarguy View Post
I've experimented a little with EOC in my van, and I don't think it's worth the risk. My van appears to have DFCO, so I'm not using up fuel when going down the steep hills, and I have important things like power steering and power brakes available as needed, and I get the braking of the engine. With the engine off and in neutral, the steering is extremely stiff, the vehicle accelerates too fast, and terminal speed is way above the speed limit, and you only get a few stabs at the brake before you deplete your vacuum storage. So I'm going down a steep long mountainside, picking up speed, very unresponsive steering and brakes... Not for me. I will be trying it more in the Metro though.
You Metro probably also has DFCO. I think they started putting it on most cars in the '80's. I know my '88 Escort has it.
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 01:28 PM
Out of gear coasting safety tasdrouille Hypermiling / EcoDriver's Ed 42 09-25-2008 07:18 PM
EV Mode Coasting - go to Neutral? cephraim General Efficiency Discussion 0 08-29-2008 10:21 AM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
