Old 11-26-2008, 12:02 AM   #11 (permalink)
Sort of related to that...Porsche fitted a system by Boge on the front of the 911 series as an option.
The idea was the vertical movement of the front provided power to provide pressure to power the self leveling at that end of the car.
The logic was the self leveling ensured the front of the car was at the optimal attitude of aerodynamics (and headlight alignment as an aside) regardless of the luggage placed in the trunk , which was at the front since the engine was at the rear.
Worked well but was not cheap to fit or maintain.
Pete.
Old 11-26-2008, 12:08 AM   #12 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
That is just too awesome and simple to believe. I had never even though of somehow capturing the energy of the cars bounce. Technology shall save us all.
Old 11-26-2008, 01:47 AM   #13 (permalink)
I have been intermittently follow this technology for several years mostly because the same thought had occurred to me back in the mid-nineties. As has been mentioned a few times, this is essentially the same technology as is being used in wave generation. Here is a link to a Rockwell abstract from a few years ago.
Frictionless Linear Electrical Generator for Harvesting Motion Energy - Storming Media
The reason I mention them is because they came up with an extremely low friction coating which I can no longer find a link to that I helps to increase efficiency.
Following is a link to Masters Degree thesis from 2004 investigating the same idea.
Title page for ETD etd-11052004-145157
I really like this idea but would like to see actual test data to believe it. From the information released that states a max power output of up to 50KW, one would think a large buffer(maybe supercap) would be needed also. The other thought I always had was that in a particularly windy area, if the vehicle were left outside a lot then it would also be able to partially recharge in the wind.
Or if you were a bit low on charge, get a few friends to help bounce the vehicle up and down for a few minutes couldn't hoit.
JJ
Old 11-26-2008, 12:22 PM   #14 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
This is cool, great idea. Sounds like a spinoff of ocean wave power generators. Charlevoix county Michigan roads are some of the worst as well. If you could afford a low slung sports car here, you couldnt drive it without bottoming out all the time. Hey maybe thatll get the roads fixed. Free energy from garbage roads? By golly we cant have that
Winter daily driver, parked most days right now
Summer daily driver
Old 11-26-2008, 12:47 PM   #15 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Yeah, I guess living in New England can have its advantages, I would get these if they were two times as expensive (or less) than replacement shocks... Problem is that in winter here, the snow fills in the pot holes!
American by right
Ecomodder by choice
Hypermiler by necessity
Old 03-19-2010, 04:30 PM   #16 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Bumping with a new link
Regenerative shock absorber recovers energy from bumps in the road
They predict that a full-scale system on a four-wheel car should be able to recover up to 256 watts under these driving conditions.
“For typical driving conditions, we are predicting the ability to harvest approximately 64 watts per wheel, for a total of approximately 256 watts,” says Zuo. “This value increases considerably when the system is used on irregular roads.”
Irregular roads? Like outside of the laboratory? Yeah, I know a few...
250W is short of multi-kW, but should be noticeable. I wonder what the weight penalty is, though.
Piwoslaw's Peugeot 307sw modding thread
Old 03-19-2010, 05:12 PM   #17 (permalink)
MPG>HP
Little Blue - '09 Focus SE
Team Ford
90 day: 34.41 mpg (US)
That looks awesome! You wouldn't need an alternator if you had those "regen" shocks.
Old 03-19-2010, 05:42 PM   #18 (permalink)
um... couldn't you just tie buttkickers onto some part of your suspension, wire them through a bridge rectifier & a rail of 7812's and be done, today, without changing anything about your car?
2002 WJ Overland E85/gas flex
2002 Motobecane 700DS
1978 ChevroLegs
Old 03-19-2010, 06:03 PM   #19 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Piwoslaw -
256 watts / 12 volts = 21.3 Amps.
Ha ha, on old European cobblestone roads, I'll bet you could have an electric Smart going round and round in circles. The bumpier it is, the closer it is to achieving over-unity, .
CarloSW2
American Solar Energy Society
Old 03-20-2010, 01:40 AM   #20 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Originally Posted by cfg83 View Post
Piwoslaw -
CarloSW2
I don't really think it's over-unity in that case? Although all the energy does have to come full-circle, even though it's through several different circuits.
I guess it could be that way, really...
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
