Old 04-28-2009, 12:40 AM   #1 (permalink)
Tuning an 1993 Geo Metro Up from 32 MPG.
200K Miles 1993 Geo Metro 2 Door no frills Geo Metro.
Want to restore it to the 40 MPG Range.
Replaced all the ignition components and all the plugs are Grayish white so the actual ignition process is working.
$850 Car so the strong motor and transmission are all I could expect.
So what are the Top Ten Things to inspect to get an extra 8 MPG?
Old 04-28-2009, 01:01 AM   #2 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Change your driving habits to suit your commute. Also, remember to replace all fluids, grease all fittings, and inflate your tires to specified psi/max sidewall rating/mild over-inflation . Once you feel comfortable with your driving technique, you can move on to areo-modding (if you do long highway commutes) or tuning of the engine (in general, slightly expensive). Good luck and welcome to Ecomodder.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 04-28-2009, 07:15 AM   #3 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Automatic or manual?
Old 04-28-2009, 12:49 PM   #4 (permalink)
Manual. This is the three door basic model.
Old 04-28-2009, 05:05 PM   #5 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Compression check out?
I'd have to wonder about O2 sensor with mileage in the 32's (unless you're driving it like a demon).
Old 04-29-2009, 04:59 AM   #6 (permalink)
Yeah I was thinking O2 sensor too. $100 part I won't change it out without more evidence.
Tuning to distant AM radio and listening to the RFI from the engine there seems to be a misfire under some partial throttle circumstances. Idle OK, Full Power and Hi RPM OK.
33 to 66% of throttle...I have a bug to track down and kill.
Old 04-29-2009, 09:18 AM   #7 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
93 should have a one wire O2 sensor. You can swap it to a 4 wire from a junkyard pretty easily with just a minor bit of wiring. That will give it a faster startup and keep it working even at idle when the one wire cools off and stops working. It is a slight improvement over the stock one wire and is worth considering when having to replace it.
4 Wire Oxygen Sensor conversion - MetroXFi.com
Just replacing the one wire sensor with a new one is normally pretty cheap. Last one I bought was like $15.
I would guess 45mpg is normal for an easy driven base 5spd. So first thing is do a compression test. It should be over 175 or so. If one cylinder is lower than the others then it probably needs exhaust valves. Just get the stainless ones from 3tech and they will never go bad again.
If compression is ok then next is O2 sensor. You can take it off and test it with a propane torch and voltmeter as listed in that link instead of just replacing it.
Next I would check the brakes/wheel bearings. The rear tires should spin forever about like a bicycle when you jack the back end up and spin them. If the brakes drag or the bearings are bad it won't spin real easy. The front should spin pretty easy but the disk brakes have a lot more drag than drums so it won't be quite as good. An easy way to check them is to jack both wheels up and let it idle in 1st gear and see if it favors spinning one wheel over the other. Get full loaded calipers if one of them is dragging. It is usually the slider pins that get stuck and are very hard to get working properly again without just replacing the whole thing.
Those are the main things I can think of that cause bad mileage. Hopefully you can get it back up to just under 50mpg with easy driving and keeping it 55mph and under.
My Convertible Metro XFI Plug in Hybrid Project build log
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
MPG Gauge for the Geo Metro XFi Wayneburg General Efficiency Discussion 2 03-10-2011 07:48 PM
1990 Geo Metro hatchback; improved mpg 90metro Success Stories 9 04-07-2009 10:25 PM
1993 Geo Metro brake rotors won't come off LibbyMetro Off-Topic Tech 19 03-02-2009 08:46 PM
F/S 1993 Geo Metro XFI $1500 in new parts in NY fly in drive home shanksyamaha For Sale 0 12-26-2008 01:58 PM
