Old 12-08-2016, 04:49 PM   #41 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
What about eddy currents? German inventor Dirk Strothmann's Magnic Light iC uses eddy currents to generate electricity from bicycle wheel.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 12-09-2016, 08:24 PM   #42 (permalink)
Originally Posted by gumby79 View Post
2028 Extreme 800Kv Brushless Motor
This 10hp RC motor is rated at 12s (series x4.2v =50.4v x 800kv = 40,320 rpm and a max rpm 45,000.
10hp burst( 60sec)how long do you expect to be wide open this seems long enough.
with the standard 50% derate for continues is a potential of 3kw of recovered electricity
Are you sure it could work as a motor-generator, in a way similar to the starter-generator units still used in some small aircraft? Anyway, you would need to keep it somehow protected from the excessive heat irradiated from the turbo.
Roster the link is not working says under construction.
Search for the Isuzu Ceramic Aska that you're gonna see some pictures and drawings, even though they don't provide accurate info about the regenerative setup.
Old 12-10-2016, 08:23 PM   #43 (permalink)
Buggie - '01 Vw Beetle TDI Gls
If you could make a new turbine wheel with magnets, all you would need is a coil to pass them against. Like a magneto on a lawn mower. Or better yet, put an air conditioner clutch othe alternator, and hook the clutch up to a brake switch. Oly spin the alternator when raking or needed.
Old 12-11-2016, 03:09 AM   #44 (permalink)
Heat kills magnets.
It needs to be exhaust side/clutch/alternator/clutch/intake side. The it can act as an electric supercharger or an exhaust driven alternator as needed.
Old 12-11-2016, 03:19 AM   #45 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
I was thinking exhaust / compressor/ alt. With the alt in the incoming ambant streem for plenty of cooling. 1)Use an ultra small 2 u joint shaft to alow some distance from the compressor wheel.. 2) use a very small lovejoy type cuppling.
this is a neet alternative.
series hybrid any motor
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 12-11-2016, 03:27 AM   #46 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
series hybrid any car
Former
87' Hyundai Excel
Old 01-16-2017, 04:52 PM   #47 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
I called Turbonetics teck department... and yes we can regulate shaft speed to a specific max rpm is an achievable goal. Just open the waste gate.. teck said 20,000 was a very reasonable goal.
Freebeard.
Atmospheric temperature is all the genhead would see and a fraction of that as the suction of the impeller would have a cooling effect. Run off the cold side.
bandit86
Do you mean intake inducer (cold side) insted of ehxsost exducer (hot side)?
Former
87' Hyundai Excel
Old 01-16-2017, 07:12 PM   #48 (permalink)
teoman's Avatar
A3 - '12 Audi A3
This one is water cooled and can go to higher rpms.
Hobbywing Water cooled brushless motor ESC with water cooling jacket hobbywing Neptune series 2040SL 4800KV ship-in Parts & Accessories from Toys & Hobbies on Aliexpress.com | Alibaba Group
