Old 07-26-2009, 06:23 AM   #31 (permalink)
blueflame's Avatar
Originally Posted by ConnClark View Post
Try modding a cold air intake. Diesels are more efficient with cold air. Also try and come up with a ram air intake. That will help a little too.
This paper below shows the correlation of intake temperatures and efficiency of a modern diesel engine. (see the graph at the bottom left of page 5)
http://www.buet.ac.bd/me/icme/icme20...ME05-TH-35.pdf
I had a good read there.
The test was done at 30-60 degrees C, 30 being better than 60.
I have no instrumentaion, but would hazard that cold air in Auckland NZ this time of year is about 8-12 degrees C and that the temp of my air after it has been heated on the exhaust manifold after passing throught the air filter and 2 plus feet of intake ducting would be about 30 degrees C, just going on holding in my hand the intake ducting near entry to the engine.
I feel the test condition need to be expanded to appreciate warmer air benefits in climates colder than 30 plus Degrees.
Old 07-26-2009, 10:35 AM   #32 (permalink)
THE DODGE - '06 Ram 2500 ST
90 day: 22.64 mpg (US)
The Saturn - '08 Vue XR
90 day: 21.94 mpg (US)
The Odyssey Van - '011 Odyssey EX-L
90 day: 29.1 mpg (US)
The IAT's tested are in the correct range for the motor tested given ambient temp ranges going through the entire intake tract. I have a very similar motor and have monitored these temps before at various loads, temps, conditions, ect. Each motor may vary some in the temps they operate best so keep this in mind.
New here with 2006 Dodge Ram 2500 Turbo Diesel nubbzcummins Introductions 3 09-02-2010 01:35 AM
63mpg in a 1986 Isuzu Trooper Turbo Diesel TheWildHippie Success Stories 18 08-10-2010 11:40 AM
Diesel Power Magazine Fuel Economy Shootout JQmile EcoModding Central 3 03-18-2009 09:23 PM
Wanted (1st gen VW turbo diesel) 3lr For Sale 19 10-28-2008 03:28 AM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
