Old 08-03-2009, 11:46 PM   #11 (permalink)
THE DODGE - '06 Ram 2500 ST
90 day: 22.64 mpg (US)
The Saturn - '08 Vue XR
90 day: 21.94 mpg (US)
The Odyssey Van - '011 Odyssey EX-L
90 day: 29.1 mpg (US)
All of my tanks are filled to the same level, at the same station, with the same pump every time. I fill to the brim for consistency. How is this not valid?
Old 08-04-2009, 01:05 AM   #12 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Air bubbles in the tank. I get over half a gallon variance from tank to tank taking the same measures.
Old 08-04-2009, 03:39 AM   #13 (permalink)
Not wearing pants
I don't know about getting a half-gallon variance due to air bubbles in the tank, but for me, it still wouldn't matter. I do my fill-ups the same way, right to the very brim each time, same station, same pump. If I go 685 miles on a tank, and put in 38 gallons, I get 18.0mpg. If I suffered from massive air bubbles in the tank and could have actually fit in an extra half gallon of fuel, then I would have only actually gotten 17.8mpg. 17.8/18.0 = 99% I think that's close enough, especially when I don't believe in half gallon bubbles.
Old 08-07-2009, 09:48 PM   #14 (permalink)
Even tho there are air bubbles in the tank/fuel they will be consistent as long as you fill up at the same rate with the pump every time..........which I do.
Old 08-08-2009, 03:06 AM   #15 (permalink)
Not wearing pants
Good point!
Old 08-10-2009, 01:51 AM   #16 (permalink)
DieselMiser
ConnClark's Avatar
Not true. When you fill it to the brim the air bubbles that gurgle out of the tank are what determine the final rate at which fuel flows into the tank. There is no way to get the gurgling to be consistent.
Even if find a way to to fill it the same each time you would still have too much variance in the road travel draw any valid conclusions with just one tankfull.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 03:29 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 01:22 PM
Psychological Ways of Saving Fuel Wayneburg General Efficiency Discussion 22 06-06-2008 10:24 AM
