Old 07-03-2008, 07:54 PM   #1 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 j30
90 day: 22.74 mpg (US)
Turbo VX?
I'm just going to run this by you fellas and see what kind of feedback I get.
I have the VX engine and trans going in my LX (when I get some free time) and I was thinking that if I put a turbo on it that would engage at the same RPM as the vtec (find the right one) then I could effectively have a car that would get 50MPG when I stay under 2k and be fun to drive when I want to take it to the strip.. now here's how I think I could make it work. Last summer I put a turbo kit on a friends integra that actually had a plate that went inbetween the throttle body and the intake manifold that had 2 injectors in it, they only sprayed when you got into the boost, so when you drive normally, no extra fuel is used. The other thing I'm hoping is that I can run regular gas when I drive normally, and when I drive it at the track, I can run premium and have no issues.. This is all depending on the d15z1's compression ratio though, anyone know what is is off the top of their heads? and what are your thoughts on this.. see any flaws other than the possible compression ratio issue?
Old 07-29-2008, 06:10 PM   #2 (permalink)
Red Egg - '95 Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
i hope you have a good source for multiple vx drivetrains
Old 07-29-2008, 09:34 PM   #3 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Aftermarket turbos on any NA vehicle are an iffy proposition at best. You'd be better off taking the same money, and getting a 2nd car as a toy.
...that is unless, of course, you <i>enjoy</i> having connecting rods punch holes through your engine block.
Old 07-29-2008, 09:36 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I see not many people have boosted hondas in the past. You'd need to work out the tuning yourself, would be easy if you got rid of lean burn, but very possible.
Old 07-29-2008, 10:33 PM   #5 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
Last 3: 58.02 mpg (US)
Good tuning is key to a long healthy life on a stock engine. For example there are two civics here that push 200+ hp and 170 tq on bone stock engines, and I mean untouched One engine, d15b, was making about 175hp for 30,000 miles and started to smoke but still ran fine, engine had 215,000 miles total. D16z6's have been know to push over 300 hp pretty reliably. I recommend using Neptune or Hondata for engine mngt and have a good tuner @ hand.
You are going to spend @ least $2500 for a good quality kit installed yourself and tuned professionally. So yeah, its a bit of pocket change.
Actually leanburn can still be had on a tuned turbo vtec-e engine. It can even be tuned to be more efficient than the factory tune
A coworker of mine is going to install a dual stage vtec d15b this weekend and use Hondata S300 and Locash for tuning. The engine has leanburn, vtec-e, and a normal vtec and can be tuned from top to bottom with the s300.
The head ports and valves are pathetic compared to a d16y5 hx engine but still respond well to forced induction. Imo 175hp is the reliable limit for a d15.
A few companies sell custom rods and piston kits for a d15 that allow much higher boost pressures and people have had 500+hp on them.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Turbo to drive accessories? reformed EcoModding Central 14 06-22-2008 04:28 PM
going back to VX roots from D15B soch vtec Nden Introductions 14 05-19-2008 02:35 AM
