Old 04-21-2011, 06:49 PM   #1 (permalink)
Leviticus - '97 Sebring Convertible JX
90 day: 21.33 mpg (US)
Fiesta - '012 Fiesta SE
90 day: 30.53 mpg (US)
Turbulators?
I think that's what they're called, the spike-like things on the roof of the car where it starts to curve for the back window, seen them mainly on Mitsubishi. Question is: DO THEY REALLY HELP?
Do they make the car more aerodynamic, apparently they're supposed to "trip" the airflow, I think by decreasing the size (or something) of the vortexes that occur at the end of the car. Any thoughts, advice, data?
Old 04-21-2011, 06:51 PM   #2 (permalink)
Here is a picture of what I'm talking about. The 8 spike/bumps on the side of the antenna.
Old 04-21-2011, 06:59 PM   #3 (permalink)
XJguy's Avatar
They work in conjunction with that wing. Those delta-vortex generators basically bend the air coming over the roof to interact more with the wing. With no wing they serve no purpose in that application. Its about down-force, not drag reduction. In fact they add drag.
Old 04-21-2011, 07:25 PM   #4 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
they do what they claim to "help keep the airflow attached" but test after test on here has proven that they don't help the aero behind the car. i do have a friend that placed them under his car about 6 inches from the front of his belly pan and it reduced the "floatiness" of the car when dealing with crosswinds (and passing semi-trucks, when dealing with the air deflected to the side by the flat front)
Old 04-22-2011, 12:50 PM   #5 (permalink)
AeroModder's Avatar
Darwin - '96 Aspire 4 door
Team Ford
90 day: 44.82 mpg (US)
On the Evo, they reduce the drag coefficient by .006.
In Reason we Trust
Old 04-22-2011, 02:48 PM   #6 (permalink)
- - '010 Prius III w/Navi
Hi Capn..,
Those delta shaped things are VORTEX GENERATORS. A TURBULATOR is a thin layer of material with a zig-zag cut at the leading and trailing edge.
Vortex Generators help air flow around a sharp corner, but at the expense of some drag. The overall drag , properly design, is not that much different.
A turbulator introduces turbulence into the air flow. There purpose of turbulators is to prevent flow momentum causing the air to continue in its present direction, but to tumble and conform to to the shape of the airframe.
You have seen an application of the Vortex Generator, on the EVO to get the air to flow over the rear wing.
Turbulators are used on sail plane wings to prevent the air from going higher over the wing than the wing is, resulting in flow seperation.
On this site we have discovered that when you have a steep windshield angle, some small benefit can be had by putting a turbulator on the upper 1/3 of the A-pillar. Thus the air flowing diagonally across the windshield conforms to the flow down the side of the car, quicker. This is because with a steep windshield, some of the air in the outside corners is going sideways as it hits the upper 1/3 of the A-pillar. And it has momentum to shoot out sideways larger than the car actually is. By exhausting the energy asociated with this momentum, the air will combine nicely with the flow down the side of the car.
The Following User Says Thank You to donee For This Useful Post:
mort (04-22-2011)
Old 04-23-2011, 01:23 PM   #7 (permalink)
Thanks for the explanation!
I was looking at another site for car aerodynamics and it called those things turbulators.
So these are turbulators-
Old 04-24-2011, 11:58 AM   #8 (permalink)
Hi capn..,
Yes, those are turbulators.
Old 04-24-2011, 12:28 PM   #9 (permalink)
XJguy's Avatar
OP here is all the info on the Evo vortex generators.
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
Old 10-29-2011, 10:39 AM   #10 (permalink)
Yeah, old thread, but I use the search function
Anyone know if the person from the car pictured bought or made that strip?
So these are turbulators- {{I can't post images yet, see above}}
