Old 12-23-2014, 10:20 PM   #1 (permalink)
Supra - '88 Toyota Supra
superhawk - '98 Honda superhawk
Last 3: 27.62 mpg (US)
Lesabre - '96 buick lesabre
3800
90 day: 25.85 mpg (US)
Saturn - '97 Saturn Sc2
Team Saturn
Sports Cars
90 day: 39.12 mpg (US)
Truk - '99 Ford F150
Team Ford
Pickups
90 day: 24.43 mpg (US)
Golf - '03 Vw Golf
90 day: 38.57 mpg (US)
turning on engine with out killing accessories automatic?
I have a 96 lesabre that I would like to install a kill switch for eoc but it has an automatic transmission so I will have to use the starter to get the engine going again but I don't want to loose power to my ultra gauge radio and other accessories. Has anyone covered this before? Any ideas?
Old 12-24-2014, 01:09 AM   #2 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
You would want to do it two ways: wire it to your fuel injectors, and another switch to your torque converter lockup. Engage lockup first! Then cut off injectors. You maintain power to your accessories and the locked up converter still allows your transmission's fluid to be pumped, keeping you from trashing the transmission in a month or two. The two-switch setup is the best I can think of unless someone can think of a better setup for a GM full-size FWD.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 12-24-2014, 09:57 AM   #3 (permalink)
3800
Team Saturn
Sports Cars
Team Ford
Pickups
Golf - '03 Vw Golf
Having a torque converter lockup switch could also boost my fuel mileage so I'll make sure to do that asap. I am planning on cutting power to the injectors but I want to be able to activate the starter without it shutting off everything else
Old 12-24-2014, 10:04 AM   #4 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Is the UG set on hybrid mode? rewire the radio to have a constant 12V.
The head lights will probably still go out.
Old 12-24-2014, 12:18 PM   #5 (permalink)
Experienced UAW Mechanic
Playing with the converter lockup is a great way to hurt the converter. It's only there for helping MPG at light-throttle cruise, nothing else. You go trying these ideas, you'll be needing a custom triple-clutch converter at well over $1000. If there's even space for one. Sometimes you don't know better than GM, just ask the guys on LS1tech.com if you don't believe me. Or the guys on RV.net. Or I could name a dozen more.
If you want to maintain electric to the radio with the engine off, then replace the ignition hot with a constant hot. But cruising with the engine off means the ATF isn't getting pumped.
The correct solution is cheap. Swap the 4T65E for a Getrag 282 from the salvage yard.
The guys on either Fiero forum can tell you how.
Old 12-25-2014, 01:20 AM   #6 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
UG doesn't have a hybrid mode. You have to fiddle with four separate parameters to find a combo that works.
Old 12-25-2014, 02:17 AM   #7 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
On mine, I added an "auxiliary start button", it's a stand alone circuit that I wired directly to the start terminal of the starter. starting the car with the key is unaffected / normal. With the key on, the extra button can start the car. With the key off or not even in the car, the button will turn the engine over.
Old 12-25-2014, 02:52 AM   #8 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Yea it does, I can't remember what it's called, but it's basically hybrid mode.
Old 12-25-2014, 03:01 AM   #9 (permalink)
Team Turbocharged!
Pickups
I searched 'hybrid' in the user manual and didn't find any mention?
Old 12-25-2014, 03:19 AM   #10 (permalink)
Team Saturn
Originally Posted by johnlvs2run View Post
Success! Changing pwr off retries keeps the ultragauge on.
Compatibility > pwr off retries
If ultragauge at times enters low power mode and briefly turns off the display ... increase the number of retries (5 is default) until the behavior stops. A side effect of increasing the value is that ultragauge will remain on for a longer time after the ignition is switched to off. Changing this setting to a value greater than ~45 is not recommended.
Changing the value from 5 to 33 keeps the ultragauge on for 10 seconds after the toggle (ignition) is switched off. This is plenty of time to switch the toggle back on, and then the ultragauge continues to stay on.
