Turning off electric hot water heater when not home?
I have heard of people putting a timer on their electric hot water heater so that it shuts off when not in use. I'm not sure how I would go about hooking up a timer to mine, but I could simply flip the breaker when I leave in the mornings. Currently I take 1 shower per day and it's in the mornings. Other than that I almost have no need for hot water.
Has anyone tried this? How long does it take the heater to get back to proper operating temperatures? |
They work great and are easy to hook up, or if you are unsure about how to do it you can pay a pro to do it and still get a return on your investment within a year or two.
If they are available for your voltage of water heater I would go with a digital timer so that you can have it come on lets say on every morning from 5am-7am (water stays hot for 3-5 hours after that) then on Friday and Saturday it also comes on in the after noon for an hour so you can shower before any evening weekend plans. |
Excellent. I think I could install it myself. I may also install solar attic fan.
I found a problem yesterday...only the A/C is labeled in my breaker box! Everything else is blank. What electrician installs a breaker box and doesn't label 90% of the switches? |
What electrician installs a breaker box and doesn't label 90% of the switches? 90% of them, in my experience. |
i've been wondering about these timers as well. my wife and i each take a shower at around 5:30 to 6:30 each morning. we don't need hot water again until around 7 pm when we wash dishes. i also sometimes take a shower in the evening since i work either outdoors or in a metal building with no heat/air/insulation all day.
so would one of these timers be cost-effective for me? basically i need hot water 5:30-6:30 am, and around 7-8 pm during the week. would the whole tank re-heating twice a day be more efficient than keeping it on all day/night? Quote:
that stinks about the boxes. I may turn everything off for the short time I take putting the timer in.
Tony, here is some good info I found today: http://michaelbluejay.com/electricity/waterheaters.html specifically these tips: Quote:
slightly off-topic
100% of the panels I've installed are labelled......... I've been to Michael's website, it has a lot of good reading. |
Electric water heaters are insulated pretty well, so you probably won't save much by turning it off. 100% of the energy goes into the water as heat (or very nearly so), so the only losses you can save are "standby losses" from heat radiating out of the jacket. Because electric water heaters don't have a flue that tends to cool the water, they usually retain the heat very well.
If you turn it off after it is hot, leave it off for 8 hours and turn it back on, does the element have to come on to heat the water again? If it does, spend your money on insulating the tank, the pipes coming out of the tank, installing a "thermal trap" in the outlet pipe, etc. If the water in the tank is still above room temperature then you haven't lost all of the heat and you won't save much energy by waiting until you come home to turn the elements back on. The intermittent use of the elements during the day will come very, very close to the longer run you need when you turn the elements back on. |
