Old 10-11-2008, 12:32 PM   #1 (permalink)
Kawi - '04 Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Monte Carlo Z34
90 day: 26.52 mpg (US)
Turning off engine with an automatic
I've heard some posts saying that you shouldn't turn off the engine while coasting if you have an automatic. The only reason that I've found for this is that the transmission pump turns off. Are there any problems that could arise from turning off the engine? I P&G a lot and I'd like to start turning off the engine during long glides.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 10-11-2008, 12:54 PM   #2 (permalink)
coasting
My thought is that without the engine on (and pump operating as you mention ),it's the same as towing an automatic transmission car with it's drive wheels on the ground,which usually burns up the transmission.
Old 10-11-2008, 03:08 PM   #3 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
While the claims of damaging automatic transmission that are flat towed in neutral are true. This damage can occur over hundreds of miles consistently being towed in N. I EOC "Off" coast my automatic with no problems. My longest EOC is 1 mile and I do it every day. I have been doing so for the past 20K miles with no ill effect. Before doing it though I did flush my tranny and added synthetic transmission fluid, just in case ... LOL
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 10-11-2008, 05:35 PM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I tried this with my Civic once. The car has to be in park to restart the car, so I had to pull over by the side of the road.
Anyone know how to get around this ?
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 10-11-2008, 05:41 PM   #5 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I shift into Neutral several times on my 7 mile commute to work. I coast down a hill for around 3/4 of a mile ( google maps ).
I find that even when I am going down hill, shifting into N will allow the car to go from 45 at the top of the hill to around 56 MPH at the bottom of the hill.
When I leave the car in Drive, it actually seems to slow the car.
I'll verify this the next time I go into work.
I know for certain that placing the car in N on level ground will allow me to coast at least 175 - 200 yards farther than leaving it in Drive.
( Is there a problem with my transmission ? )
Old 10-11-2008, 07:16 PM   #6 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 20.27 mpg (US)
In my car, going down a hill with a steady grade, I can shift into neutral and it feels like i tapped the gas. On one car, as soon as I shift into neutral it goes from 50 to 55, and I start gaining on the cars ahead of me.
I was actually about 5-10 car lengths behind a ranger the other day when I shifted into neutral and I had to use the brakes just before the bottom of the hill because I was gaining on him so fast... he never used the brakes once.
Old 10-11-2008, 09:17 PM   #7 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
Does going into neutral wear down tranny?
Some good points in this thread and the link posted above. I looked up my vehicle in a link posted in taht thread (ability to flat towing, which can be done in my altima). Now I do a daily ~.7 mile EOC, which is about 1/10th of my daily commute. Pretty nice IMO.
Most of my trips are made in rush hour traffic to and from school.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 10-12-2008, 01:34 AM   #8 (permalink)
Boxy is Sexy
Z man's Avatar
xBox - '05 xB
90 day: 40.85 mpg (US)
Send a message via AIM to Z man
No, you are right.
the transmission holds you back when coasting.
Neutral is better!
Old 10-12-2008, 06:49 AM   #9 (permalink)
Neutral is certainly better than just taking your foot off the gas. So as long as your car is supposed to be able to be towed flat it's ok to turn off the engine, but if it's supposed to be raised then it might cause problems. What about an ignition kill switch, would that get around the problem of not being able to flat tow the car?
Old 10-12-2008, 07:56 AM   #10 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
No. An ignition kill switch does nothing to address the problems some vehicle have with flat tow.
When you flat tow, the turning of the drive wheels turns some of the internals of the transmission. If the design of the transmission is such that the transmission fluid is pumped through the system in the same manner as when the engine drives the transmission, then everything is A-OK. If the design of the transmission is such that the transmission fluid is NOT pumped through the system in the same manner as when the engine drives the transmission, then parts of the transmission are subject to overheating - potentially leading to premature failure - particularly if you flat tow the vehicle for a significant distance.
MetroMPG mailbag: how to keep SG live when engine off? MetroMPG Instrumentation 6 10-17-2011 03:44 PM
1992 Metro sedan needs a new engine - What/Where/How - advice appreciated greatly! Crono EcoModding Central 26 11-18-2008 01:42 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
