Two Bucket Car Wash System
I started using a two bucket car wash system this week …
https://www.youtube.com/watch?v=SJlnnBVQ5Lk |
My wasteful pressure washer is how I keep my 1 small patch of crab grass alive in the summer.
https://www.youtube.com/watch?v=5jz5DwML8iI :D > |
Alas, my pressure washer is on the fritz. The water here at Rancho Indebto comes from a well in the back yard. It drains back into the ground (laden with car cleaning chemicals) when it runs off the driveway. :thumbup:
So you can use more that 2 buckets of water to wash your car? But why would you??
All I do is shift some water from the back yard to the front yard. |
My Superbeetle is in storage, but it had a decent waxed finish, and the biggest problem is pine needles littering it; so I would use a drafting brush to sweep it for it's weekly drive and wash it maybe once a month.
https://www.google.com/search?q=cali...blade+squeegee I was wondering if I should recommend the [Original] California blade, so I found this article: Ask-A-Pro: Should I Use a Silicone Squeegee On My Car? | Ask a Pro Blog from the comments: Quote:
Is the purpose of this to save soap? and maybe reduce how much soap and such goes in to the soil? :confused:
