Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 05-18-2012, 09:47 AM   #1 (permalink)
evap
Data on disconnecting a evap is instant+ 5 mpg
Old 05-18-2012, 12:26 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Could you give a bit more info on that ?
Old 05-18-2012, 12:35 PM   #3 (permalink)
I disconnected the vacume line at the throttle body less vacume draw is letting my engine not work as hard is what I think is causing the increase in mpg
Old 05-18-2012, 12:58 PM   #4 (permalink)
You're going to have to give a lot more info than that. Especially considering what the evap system does (traps and burns gas vapors). What you're saying really doesn't make sense.
The Following User Says Thank You to Daox For This Useful Post:
Thelismor (09-25-2013)
Old 05-18-2012, 01:26 PM   #5 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
or it could make your car run even worse i have a small hole in 1 evap line that makes it start really rough cant imagine the entire line being gone
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 05-18-2012, 03:50 PM   #6 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
hmm it might of been the vacuum advance line he disconnected.. making the car run slower / lower rpm.
Save gas
Old 05-18-2012, 04:11 PM   #7 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
How did you measure that if you caused a vacuum leak the AFM will see less airflow and some types of instrumentation can be fooled into thinking your car is using less fuel when it isn't also punctuation is your friend
Old 05-18-2012, 05:45 PM   #8 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
happen to disconnect the vacuum line about the same time you started driving like you cared about mileage?
Old 05-18-2012, 08:08 PM   #9 (permalink)
I disconnected it and ABA tested it if you don't believe me then you all can go to help because I'm tired of everybody being an expert and an asshole to me next up is if you want the government that dissent have your best unrest at heart then leave it on. Next my truck didn't get a vac advance distribute and evap came out it the 80 s so guess everyone's car tan bad then didn't it
Old 05-18-2012, 10:09 PM   #10 (permalink)
None of us are trying to be jerks, Ramman. If you've been here any length of time you'd understand why the skepticism is worth while for us. You can't simply come here and say 'hey everyone, disconnect your evap system to gain 5 mpg' and have everyone just say 'okay brand new guy we don't even know, I'll go do that right now just because you said so'. If that were what we do, everyone here would be adding acetone to our gas, with a pill in our gas tank, and boiling water with hydrogen generators, and everyone would probably be getting worse mileage than their stock vehicles. We take the time to PROVE our modifications here, we don't take anyone's word for it. Even (actually especially) the veteran members here understand the value of testing new modifications and wouldn't make claims without information to back them up. Testing proves what works or not.
If you disconnected your evap system and it worked for you there probably is a reason (creating an unmetered vacuum leak for instance), but that may have more effects than you are aware of. There is a reason the evap system is on a vehicle, and its certainly not to reduce your mileage.
If you have done testing post the info. This is what we ask of everyone.
mcrews (05-20-2012)
