Old 06-13-2017, 02:47 AM   #51 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 17.09 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Originally Posted by ThermionicScott View Post
You're confusing the "warm" viscosity (40°C = 104°F) measure with the actual "cold" viscosity used to determine the first number in the viscosity rating. The 0W or 5W or 10W is measured at -30°C or below.
Whoops.
M1 0w30:
Pour Point, ºC (ASTM D97) -50
PP 5w30:
Pour Point, ºC (ASTM D97) -48
Thanks, I dun goofed.
Old 06-13-2017, 10:53 AM   #52 (permalink)
Something synthetic with a lot of anti-ware additive with the right viscosity for your engine.
101Volts (06-13-2017)
Old 06-13-2017, 11:30 AM   #53 (permalink)
ScanGauge <3
ThermionicScott's Avatar
Originally Posted by SH@UN View Post
All oil threads should be titled "can of worms".
True story.
Best tank (so far): 32 MPG
The Following User Says Thank You to ThermionicScott For This Useful Post:
SH@UN (06-16-2017)
Old 06-16-2017, 03:27 PM   #54 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
For the most part I usually just look at the viscosity at "running temp". Then I just compare all the oils available at wal-mart because for the most part they are really cheap compared to autozone and everywhere else and most synthetic oils regardless of category perform well enough to not worry about them in a passenger car.
What was interesting is I ended up comparing all of the 0w-20 oils for the prius i could find. Mobil 1 (26) had a 8.7 @100cst, pennzoil platinum had a 8.3 @ 100cst (25), quaker state (20) had a 8.3 @100cst, valvoline (22.5) had a 8.8 @ 100cst, etc...
And just for fun redline 0w20 is 9.1 @ 100cst
Just for fun Ravenol 0w-16 was a 7.1 @100cst
The API considers 8.2 the upper threshold for 0w-16w oils. So they are no 16w but all the 0w-20s are pretty thin for the most part.
Its not super technical but I ended up getting the quak state 0w20 for 20 bucks because a 0w-16 honda oil change was $45 dollars, and so was ravenol. Not worth that 1-2% gain for double the price of oil.
And i'm already running pennzoil platinum 0w20 and in 400 miles i'll be coming up on 10k so ill send in the blackstone oil analysis and see if they recommend to keep the oil in longer. All about running your oil the smartest way you can I think if you're going to keep the car for a long time.
When my dad was a branch manager for Terminix they had a large fleet of Ford rangers covering two counties that for the most part all had higher running cost but all ran to 250k+. He said the company at one point actually went through and changed all the maintenance intervals to higher intervals to maximize profits and because they were doing the factory maintenance intervals and had people come in and determine it wasn't completely necessary. They ended up upping (in like 2003) all their oil change intervals to 7500, changed when they changed the coolant out, added transmission coolers, did more etc... but I do not remember to all of their trucks and they apparently saved a ton of money and there trucks were still running to 250k+ before they sold them off. Pretty neat.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 06-16-2017, 04:20 PM   #55 (permalink)
ScanGauge <3
My 1996 Subaru manual says to change the oil every 6500 or 7500 miles (can't remember which without having the manual in front of me), and doesn't require synthetic at that. It's amazing (and incredibly wasteful) how the old 3000 mile oil change is still fixed in people's minds.
Old 06-16-2017, 04:39 PM   #56 (permalink)
Yup my 1996 (not that it could bc they are all oil chuggers) had an interval of 10k oil change, 15k filter. Thats crazy.
