Old 09-09-2009, 04:55 PM   #1 (permalink)
Tyre pressure monitor system
Just found this system for sale in the UK, it comes with 4 wireless sensors, 4 alloy valves, the main unit and power adaptor.
Tyresure 4 Wheel Car and Small Van - £179.00 : Ecotune Sussex, fuel saving, wheels and tyres
They say to contact them if delivery is to be outside of the UK.
Just thought it might be of use to somebody, Measures up to 60PSI too..
Old 01-21-2011, 03:14 AM   #2 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 66.4 mpg (US)
Tire Pressure Alert Valve cap - Tire Pressure Alert valve cap
Have anyone tried these? They promise 3 weeks battery life, when blinking? Works with pressures up to 120 psi
www.tuneko.com
Less drag = Less fuel
Old 01-21-2011, 11:36 AM   #3 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
I don't see any details on this. Is it possible to set the alert pressure? And does installation promote slow tire leakdowns like a previous products I tried?
It would be pretty useless if you can't set the alert pressure to something useful for folks who run pressures over 30 psi...
Old 01-21-2011, 01:36 PM   #4 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
On the link in the first post I'm seeing an ad for adult movies, just in case someone clicks on it. The ones after that seem fine.
No longer here. Bye, and good luck to all.
Old 01-21-2011, 03:23 PM   #5 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
A few years back I bought some tire pressure valve caps from Napa Auto parts that changed color when the pressure dropped by more then 4psi, they looked alot like these and measure PSI of 26, 28, 30, 32, 34, 36, 38, 40, 45, 50, 55, 60, 65, 70, 75, 80, 85, 90, 95, 100, 105, 110, 115 and 120
The ones I had were of another brand but I never had issues with them, they were 50PSI and warned me a number of times of slow leaks that I then repaired.
pressure, tires, tyre
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
Hello from Texas spil Introductions 2 09-03-2008 06:38 PM
