Old 12-17-2009, 09:55 PM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Okk, I finished today!!!12-17-09
I am going by my muffler shop tomorrow to take pictures.
I was on the hwy that I made a test run on last month so I hit the re-set button and got in the slow lane.
Only did one run but I got 28.9mpg.
Which is about 2 mpg lower that last month with just the front pan.
It was colder (by 15 degrees) and wetter. not raining but overcast anf damp.
But, it's CA and the weather will get better!!!
I am guessing that the fuel formula is also different than a month ago?
Old 12-18-2009, 11:07 PM   #12 (permalink)
mcrews's Avatar
Feel a little better today.
Got 29.7mpg over the same distance at 60mph.
It was warmer today.
Old 12-24-2009, 05:22 PM   #13 (permalink)
mcrews's Avatar
finished....pics
Here is the view form a lift at the muffler shop.
BTW the shop owner was VERY open-minded about the whole process. He must have had 5 different people looking under the car!!!
From the rear- driver side:
from the rear passenger side:
Down the center:
the squarish cutouts are where the exhaust pipes dipped too low....so I used screen material. This way the heat disapates out but the screen acts as a smooth surface for air flow.
I need to get a panel here still:
front pan looking from the back:
Front panel from the front:
transmission section from the front:
The Following 6 Users Say Thank You to mcrews For This Useful Post:
aerohead (04-09-2010), beluga (01-02-2014), landsailor (06-09-2011), mikeyjd (05-28-2014), Regenerit (04-15-2012), viio (04-02-2012)
Old 12-24-2009, 05:27 PM   #14 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
mcrews -
Thanks for the pix! You're getting the word out!
CarloSW2
American Solar Energy Society
Old 12-24-2009, 05:56 PM   #15 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 current (2018) - '98 Toyota T-100 SR5
90 day: 19.99 mpg (US)
Send a message via ICQ to BamZipPow
Looking great!
Something that you might want to consider...visibly mark the jack points so a jack doesn't go through the floor pan by mistake.
The Following 3 Users Say Thank You to BamZipPow For This Useful Post:
Arctic Fox (02-14-2012), Fr3AkAzOiD (12-29-2009), mcrews (12-26-2009)
Old 12-26-2009, 12:36 AM   #16 (permalink)
mcrews's Avatar
BamZipPow,
EXCELLENT POINT!
I am actually going to install blocks of hard wood, that have been wrapped with black gorilla tape and have a metal strip just under the tape. I'm planning on 1x4 x6". then pre-drill holes in the metal/wood and a smaller hole in the mounting point.
Old 12-26-2009, 11:27 AM   #17 (permalink)
90 day: 50.45 mpg (US)
Winter beater Metro - '00 Chevrolet Metro
90 day: 64.43 mpg (US)
Added this to the project library.
About your early on-road MPG results: A-B-A testing of undertrays isn't really practical. I managed to do A-B testing of my full undertray, and measured a ~2% change (see Metro undertray / belly pan ). Apples/oranges, though - every vehicle is different underneath.
As long as you're not increasing frontal area (doesn't look like it), you can be sure this helps.
Latest mods test: 15 mods = 15% MPG improvement: A-B test, 2007 Honda Civic 1.8L, 5-speed
Ecodriving test:
Manual vs. automatic transmission MPG showdown: Nissan Micra 1.6L
Old 12-26-2009, 12:09 PM   #18 (permalink)
I don't think you should cover the exhaust pipes at any point along their length, regardless of how high or low they are
Old 12-26-2009, 12:15 PM   #19 (permalink)
mcrews's Avatar
....because it traps the heat?
Old 12-26-2009, 01:21 PM   #20 (permalink)
Yeah. Cars with underbody panels leave the exhaust pipes uncovered, I assume because they need the airflow
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
