Old 11-21-2009, 10:40 PM   #1 (permalink)
Under belly pan
I'm considering using aircraft aluminum to make removable panels under the vehicle. What thickness do some of you recommend? Thanks!
Old 11-22-2009, 01:02 AM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I made an engine cover out of aluminum flashing that I riveted to aluminum bracing.
It rattled and made all sorts of weird noise when the car was at idle.
I went to a thicker aluminum ( about the thickness of a dime ) and that solved the problem, but the thing is surprisingly ....heavy !
I would suggest using coroplast. There are several members here that have used it successfully.
It weighs much less.
( And one more thing - coroplast doesn't have razor sharp edges either )
Old 11-22-2009, 03:20 AM   #3 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.66 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 42.45 mpg (US)
Awww come on, sounds like a great anti theft device to me. Don't have to worry about anyone hiding under your car.
I folded the edges over and glued them on mine. Hardens the edge up a bit and keeps it from being razor sharp.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 11-22-2009, 12:44 PM   #4 (permalink)
Eco Dreamer
Versa - '08 Versa SL Hatchback
For something like a bellypan that requires a lot of cutting and fitting and contouring around uneven surfaces, etc. I agree that coroplast is probably the easiest way to go. Maybe just use aluminum right by the cat.
Old 11-22-2009, 03:59 PM   #5 (permalink)
Thanks CD! I assume that colorplast is cheaper than aluminum and easy to work with.
Old 11-22-2009, 05:07 PM   #6 (permalink)
CD - I Googled colorplast and found a company that makes it: there were 30 different materials available, not to mentioned thickness choice - yikes! Any recommendations?
Old 11-22-2009, 05:42 PM   #7 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Election signs. Or, the same stuff, as commonly available at lumberyards.
Old 11-22-2009, 08:04 PM   #8 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
I bought some Coroplast last week for about $13.60 per white 4x8x4mm sheet. Closer to $17 for colors. I first called a number of sign shops, because they use the material for signs, and I was hoping to recycle some old signs, but nobody had used stuff, so I asked them where they got their materials. A few different sign shops gave me some contact info on a few different suppliers, and the place I ended up buying from had a lot of different sheets of a lot of different materials, but they seemed to deal mostly in raw materials for sign makers. Look under signs and plastics. Good luck!
Old 11-22-2009, 08:18 PM   #9 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
I got mine from a sign shop, $30 for a 4 x 8 sheet.
Old 11-22-2009, 09:01 PM   #10 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...put strengthening "creases" in ALL flat panels (like airconditioning ducts have) to halt 'tin canning' due to turbulent air flow and mechanical vibrations.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
mcrews (11-22-2009)
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Honda Fit Belly Pan Project Fit Aerodynamics 15 03-10-2011 04:32 PM
Aerodynamic Belly Pan on Toyota Echo jimepting Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
