Old 06-28-2008, 10:37 PM   #11 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
I like that better still, the long lugnut with blind hole. Drill and tap the end for something simple like 1/4-20. Of course be aware that drilling and tapping grade 8 (typically all automotive fasteners are grade 8) is harder than plain old mild steel. Itll take more time and patience. And you can get 1/4-20 grade 8 bolts at Lowes or Tractor supply or most hardware stores and they dont cost much.
The best thing would be if the ends of the lugnuts were a hair shorter than the inside face of your flat wheel cover when it is in position. You could use a grinder or lathe and cut the nuts down if necessary. Or if the ends of the nuts are too short, what would probably be easiest is to glue washers to the inside face of the wheel cover until you get the right height. Use JB weld or metal epoxy. Either way you need to make sure you bottom out the wheel cover and bolts onto the ends of the lugnuts, or the bolts will just work their way back out.
Edit: If wheel lugs are not grade 8, then are they grade 5? They certainly should not be grade 2.
Winter daily driver, parked most days right now
Summer daily driver
Old 06-28-2008, 10:38 PM   #12 (permalink)
EcoModding Newbie
RSX - '02 RSX base
90 day: 37.87 mpg (US)
Flat wheel cover
I found these in ten seconds of searching, capads.com. Im sure there are plenty of flat wheel covers you can find with out modifying what lug nots your using and making your own covers.
Old 06-28-2008, 10:58 PM   #13 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Yep, check out the installation images and you will see what I am talking about first hand. At least my way you by pass all the expense of a static bearing and additional hardware ..
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 06-28-2008, 11:01 PM   #14 (permalink)
OK for S&G's I emailed the company and told them my mechanic lost several of the connectors. I asked them where I could obtain replacements and how much ... I'll let you guys know when they respond .. LOL
Old 06-28-2008, 11:29 PM   #15 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Wheel covers on dually trucks are attached in a similar manner.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-06-2012 11:40 PM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 21 01-06-2010 05:54 PM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
