Old 06-28-2008, 03:43 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Universal Flat wheel Covers
I was just thinking of a way to adapt flat plates to any rim without changing the wheel and I came up with this;
-Remove 2 lugs from your current rim
-Shop a hardware store, or online for a Ferrel or Ferrule Nut that will fit where your lug use to be. A ferrel nut looks just like a regular nut but elongated. I am use to using them to attach trophy rods together but I am sure they make larger ones.
-Screw on Ferrel nut in place of wheel nut
-Find or make your flat plate
-Find a bolt that will fit the ferrel nut
-Tighten down and enjoy
I'm sure you will not have to use more than 2 on any wheel, three would be nice on a 5 lug set up.
What do you guys think?
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 06-28-2008, 03:50 PM   #2 (permalink)
ttoyoda's Avatar
That is a great idea.
Sometimes called a Coupling Nut.
1/2-13 x L1-3/4 x A11/16 Coupling Nut Zinc Plated | Fastenal
You could put it in the lathe and cut a taper seat on the end so it fits the wheel just like the regular lug nuts do.
Old 06-28-2008, 03:52 PM   #3 (permalink)
BINGO !!! I'm sure if they do not make them in automotive threads, you can just buy one of approximate size and use a tap set to change the threading on one end at least...
Old 06-28-2008, 09:01 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
trikkonceptz -
I like it. Will the Ferrel or Ferrule Nut come in the same "tensile strength" as a "normal" wheel nut?
CarloSW2
American Solar Energy Society
Old 06-28-2008, 09:30 PM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Thanks for the link, I had no idea what was being told about,
Sounds like a neat idea. Looking forward to someone doing it,
Old 06-28-2008, 10:04 PM   #6 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Originally Posted by cfg83 View Post
trikkonceptz -
CarloSW2
That was my first thought when I read the initial post. Make sure to get it in grade 8. If you use plain old grade 2, you will be asking for problems. You can probably get the coupling nut in grade 8 from Fastenal. Or possibly McMaster-Carr, they are an excellent place to get things like that. Ive bought from them many times.
But I really do like the idea. I have been thinking of a way to do this as well. My thought was to make up or get something that would attach to the center of the wheel, like how some cars had this little adapter for the wire wheel covers. But I like your idea a lot better. Also might as well use button head screws to attach the wheel cover, they will be more aerodynamic and will look better anyway.
Winter daily driver, parked most days right now
Summer daily driver
Old 06-28-2008, 10:11 PM   #7 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
Unless you're running four- or six-lug wheels, won't this throw your wheel balance off? That's adding a lot of extra metal. I know it's close to the axis, but still.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 06-28-2008, 10:15 PM   #8 (permalink)
ttoyoda's Avatar
That is a good point. It is a lot easier to buy high strength nuts than it is to calculate what strength you really need, since you need to make a lot of assumptions about what loads the lug nuts really do see..
Maybe you could buy those very long acorn head lug nuts, and drill and tap the top end.. That way you have the taper seat, the correct threads, the right strength steel, even chrome..
There is a whole mess of choices here, and they seem inexpensive..
Sherco Auto Supply
Old 06-28-2008, 10:21 PM   #9 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
Any thoughts of just finding a really long stud instead of a coupler?
Old 06-28-2008, 10:21 PM   #10 (permalink)
First, it shouldn't affect the wheel balance because it really isn't going on as part of the wheel. I got the inspiration from the spinner wheels and static rim designs. As far as acorn nuts, they do sell long ones and the cap end does pop off exposing the additional threading that is left all the way up the nut. I will get with my wheel supplier on Monday to see if he can give me some so I can do initial experiments with them.
TO be honest though, wheel lugs are not grade 8 I know that for sure ...
Look at that, we just created an awesome inexpensive mod ... LOL
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-06-2012 11:40 PM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 21 01-06-2010 05:54 PM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
