Old 10-21-2009, 07:38 AM   #1 (permalink)
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 39.96 mpg (US)
Uses for a small Kubota diesel?
I have a 4.5 HP Kubota diesel engine (EL300-AR). It was originally from one of those flashing highway arrows. What should I do with it? I saw it on craigslist earlier this year and couldn't say no. I was thinking bike or trike, but that might never happen. I could make a generator, but that's no fun to ride.
It's tempting to run it on WVO, but I'm not sure how tolerant it is of that stuff.
Old 10-21-2009, 10:15 AM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
If it's not too big or heavy, maybe a range-extending generator for an EV or hybrid? Assuming you already have one, of course
Piwoslaw's Peugeot 307sw modding thread
Old 10-21-2009, 11:54 AM   #3 (permalink)
surly teady bear
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
aux power for a small sailboat?
Old 10-21-2009, 12:12 PM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Here's a half-baked idea for a 15HP diesel engine: you could do a gasoline/diesel hybrid. Have the engine drive a fifth wheel located beneath the cargo floor of your Civic wagon. Use the gas engine when you need to go 0-60 in less than a minute, and use the diesel for cruising. It's a poor man's cylinder deactivation / bi-fuel scheme.
However, 4.5HP will give NEV-like performance in any road car. 40mph, tops. 0-30, eventually.
In order to achieve highway speeds, you're going to need a streamlined, two- or three-wheeled vehicle, preferably under 500lbs.
Old 10-21-2009, 12:19 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
It would be killer on my moped
Old 10-21-2009, 12:38 PM   #6 (permalink)
Custom User Title
It's 2 feet long and weighs 100 lbs.
Old 10-21-2009, 12:59 PM   #7 (permalink)
Custom User Title
One of the reasons I might not build a trike is the difficulty of finding a suitable transmission. With a max RPM of 2000, it's going to need multiple gears to acheive a respectable cruising speed and still be able to accelerate. I have a 3-speed lawnmower gearbox that would be OK, but it's designed for a vertical shaft engine and is grease-lubed. My other concern is MPG. I'd hate to go through the trouble of building something and then find out it gets only 61 MPG and has a top speed of 34 MPH. It would have to get about 100 MPG and go 50 MPH for me to build it.
Old 10-22-2009, 09:02 AM   #8 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Altima GXE
90 day: 30.07 mpg (US)
i would second the WVO generator setup for range extender.
At that RPM you are not going to get much direct drive applications without some customer parts.
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 10-23-2009, 01:51 AM   #9 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
It would be the ultimate "cruise engine"- get up to cruise speed, activate Kubota, shut down regular engine, sip! (might need a sub-Metro sized vehicle to do that on though)
Old 10-23-2009, 02:48 AM   #10 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Why such high expectations? What do you have that even comes close to rivaling that now?
Being more realistic, 61MPG on diesel which is basically free (if you make it yourself) is still a sight better than 100 MPG on $3.00 a gallon gasoline.
Average cost of BD when you make it at home, and using free WVO to make it, is about 90 cents a gallon, last I heard. At the price of the gas station next door, $2.70 a gallon for gasoline, I'd have to get 90MPG gasoline to match 30MPG diesel.
Your speed limitation isn't really all that realistic, either, I think. How many days do you really HAVE to go 50 MPH? Could you not suffice with 35-40 MPH?
Beyond that, there are many things you can do to increase the power output once you've built the project and gotten it working. Later on, you can streamline it, change gear ratios, increase output and efficiency with a small turbo, etc.
Build it, then worry about the details. Very few peopele actually stick to all of their goals when building something one-off. Compromise is necessary until the thing can be considered "tangible".
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux ętre heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Geo Metro convertible / Kubota diesel engine conversion (driving!) kimer6 EcoModding Central 98 04-04-2011 03:03 PM
Why is diesel so expensive in the UK? Eddles Off-Topic Tech 17 10-01-2009 11:50 AM
Canceling out pumping losses of throttle governed engines greasemonkee EcoModding Central 60 08-03-2009 05:24 PM
Fuel efficient (small!) diesel engine for Pickup truck bennelson EcoModding Central 13 01-06-2009 03:57 AM
As I Had Thought Big Dave General Efficiency Discussion 54 09-03-2008 12:00 AM
