Differantial assembly units can use ATF.
Millions of front wheel drive cars do it every day.
Most "open" spindle gear sets appear to do just fine in ATF, the GM zexel-torson LSD is approved for use with ATF. I don't see why detroit locker and varrious aftermarket lockers would have any problem.
Any spindle set with clutches such as a GM posi unit wont do so well with ATF.
The ring and pinion gears shouldn't really care what kind of oil they are in so long as they stay wet.
I think you could have problems if you put ATF in a differential used on applications other than light duty car stuff (I wouldn't mind being wrong on this).
It seems that on paper it should work but I have never found any one that has ever tried it.
Never try swapping ATF for gear oil in a manual transmission.
Thanks for confirming that ATF SHOULD be ok in an "open" differential (no clutch plates)
My friend who builds Diffs for a living has confirmed that ATF should work on in my differential- So I reckon it may be worth a shot- now to get the time to do it!
Its also common practise for us BMW folks to run ATF in the gearboxes here- makes cold shifting much easier- I have no Qualms about doing that-or I may try engine oil as a half way (Darin seems to suggest that the oil in the metro trans is similar to 5w30 engine oil..)
My BMW 328i Mods thread
http://ecomodder.com/forum/showthrea...ead-21561.html
UK MPG for the 328i Shooting Brake
US MPG for the 328i Shooting Brake
UK MPG for my 318iS (currently piloted by the Burd...)
US MPG for my 318iS (currently piloted by the Burd...)
