Old 09-20-2011, 09:35 PM   #1 (permalink)
HighMPG's Avatar
First Project High-MPG - '90 Corolla SR5 Coupe
90 day: 30.41 mpg (US)
First Hybrid - '01 Insight Coupe
90 day: 40.53 mpg (US)
Using a JET Performance 67029 - JET V-Force Plus
Anybody have any experience with these? My FE Corolla is not OBDII but it says this can work on my years.?
JET Performance 67029 - JET V-Force Plus Details
http://www.jegs.com/i/JET+Performanc...67029/10002/-1
Toyota/Scion
V-FORCE PLUS - The JET V-Force Plus features the same power tuning technology found in JET's performance modules/programmers. The JET V-Force Plus is an inline tuning device that uses a microprocessor to optimize ignition spark advance and recalibrate the fuel maps for improved horsepower, torque, acceleration, and throttle response. The face of the V-Force Plus features backlit LCD display with built in dimmer. In addition the JET V-Force Plus allows the user to select from 14 different monitoring screens. This includes Throttle Position, Mass Air Flow, Manifold Pressure, Fuel Economy and Air/Fuel Ratio.
Works great with other aftermarket upgrades including exhaust, intake, mass air, etc
Improve horsepower and throttle response
Optimized ignition advance curves
Extensive recalibration of fuel maps
Ability to add oxygen sensor hook up for additional monitoring
Multiple ways to mount LCD included
1990 Toyota Corolla SR5 Stock Automatic 1.6 154k miles
**Project MPG 1**
**My First Hybrid Insight**
Old 09-21-2011, 01:19 AM   #2 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
it basically is a scangaugeII( with a resistor)or capacitor) to override the ECU. It's doest allow you to make adjustments...i don't believe.
I would google it and see if others are using it and posting results.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-21-2011, 05:02 AM   #3 (permalink)
HighMPG's Avatar
I wonder how it performs, I been reading up on it all night!
**Project MPG 1**
