Old 11-28-2007, 09:54 AM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Using thermocouples to offset alternator load
The topic of generating electricity with thermocouples comes up in the alternator-less threads.
So here's a link sent to me by a metrompg.com visitor that outlines quite an interesting test done with a professionally built thermocouple unit that uses both exhaust gas and coolant heat. It was fitted to a GM pickup and tested on a dynamometer:
http://mithril.camp.clarkson.edu/~helenbrk/Research/JoAE_AETEG_test.pdf
Old 09-06-2008, 04:25 PM   #2 (permalink)
Oil Tycoon
mopo3's Avatar
Siray - '09 Yaris sedan
90 day: 39.41 mpg (US)
The link doesn't work anymore. Too bad I was interested in doing this to my Saturn.
Old 09-06-2008, 04:42 PM   #3 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
I wonder why it doesn't work anymore?...........maybe it worked too well....
ollie
Old 09-07-2008, 12:18 PM   #4 (permalink)
Oil Tycoon
mopo3's Avatar
I bought a peltier heat pump from American Science & Surplus : Search Results
I've been trying to use old computer heat sinks and the exhaust manifold to generate electricity. So far I've been fairly unsuccessful. I have gotten some amps but not much, the problem is that the pump is flat and the exhaust is round. 2 things would help, a pipe shaped pump and higher Seebeck coefficient which can be achieved by using bismuth telluride instead of copper and aluminum.
