Old 08-23-2010, 12:30 AM   #1 (permalink)
Using vapors from gas already going to carb?
What i want to do is route gas to a container and draw fumes out of there and also use that gas to go to the carb after.It would use 2 small fuel pumps,one to pump to the container and from there,another one to pump from the container to the carb.Would this way cut down on the quality of the gas at the carb? This will be for an 86 Toyota engine.
Old 08-23-2010, 12:43 AM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I'd say, have a beer and do something else.
Old 08-25-2010, 12:31 AM   #3 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
I'm not sure, but it sounds as if you are trying to re-invent the carburetor, using the original, rejected design. EFI is darn near perfect as it is.
Old 08-26-2010, 09:21 PM   #4 (permalink)
the original design was made to draw vapors and use the gas that the vapors came out of? never heard of it.Do you have a link to this?
Old 08-26-2010, 10:38 PM   #5 (permalink)
No link handy, but early histories tell of carburetors made like humidifiers, with air being drawn through a chamber with fabric panels wicking up gasoline from a pool in the bottom.
Old 09-08-2010, 11:11 PM   #6 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Sounds like something I read about before. google Tom Ogle.
Winter daily driver, parked most days right now
Summer daily driver
Old 11-12-2011, 01:26 PM   #7 (permalink)
Evil Genius
LPG FTW - '96 Cabrio
The Green Bimmer - '95 525i
The White Bimmer - '94 530i
along the tom ogle thing, watch the documentary "gashole". it does a great job of explaining the tom ogle mystery (conspiracy).
i am an energy engineer and i am hell bent on developing a way to extend the range of CURRENT petrol engine technology. most of my testing is done on my 96 vw cabrio. propane conversion will be dont this spring, however, as i already have all the parts minus the tank, i am thinking about using the vapor carb to develop my own gasoline vapor draw system. a supercharger will be used to pump the vapor/air mix into the engine. fuel lines to rail will be blocked via servo/regulator assembly to avoid damage to the fuel pump and will possibly utilize the a/c system to vaporize and cool the vapor to avoid combustion outside of the cylinders. wanna use my ideas? go for it, some of them arent my ideas, im just building on some concepts ive heard about along with developing my own. this could be a great step if we can all make it work. shell oil company cant kill us all
Old 11-12-2011, 01:50 PM   #8 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
You're a what?
Old 11-12-2011, 02:15 PM   #9 (permalink)
Evil Genius
energy engineer, i was a different kind of engineer before i went back to school (combat demolitions, then consrtuction) but now i study energy efficiency. engineers in my field study wind turbines, solar panels, hydrogen as a fuel, etc. im currently trying to make my hour drive to school a bit less fuel consuming.
Old 11-12-2011, 02:17 PM   #10 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Propane conversions are nothing new, and still depend on oil wells for their distilled fuel.
That's old tech.
Almost all improvements in fuel efficiency have been based on separating air and fuel for as long as possible - currently using direct fuel injection.
Another energy loss.
Cooling the vapor will result in fuel condensing again.
I'd say look elsewhere for improvements.
It's got to be good enough to substantially beat the now onrushing direct injection ... 70 years after WW2.
Lifetime fuel consumption :
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Digital Gas Pedal skyl4rk General Efficiency Discussion 8 08-09-2010 09:17 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
Hole in gas tank mrmad EcoModding Central 5 03-18-2009 04:33 PM
What's your best bet for an automatic? Crono EcoModding Central 16 10-22-2008 01:14 PM
