Old 10-04-2010, 08:07 PM   #1 (permalink)
EV Wannabe
The Booger - '92 MX-3
90 day: 23.86 mpg (US)
V6 with 4-O2 sensors question
Quick question:
Generally speaking, on a V6 with 2 upstream and 2 downstream O2 sensors, does the PCM adjust the AFR of each bank independently based on values from their respective upstream 02 sensor, or does the PCM adjust the AFR of both banks together with combined values of the two upstream O2 sensors?
Curious is all.
Old 10-04-2010, 09:13 PM   #2 (permalink)
Depends. Most systems I know of adjust each bank (somewhat) independently. But I can imagine a low-end system that doesn't. I'd think that a 4 sensor system uses all 4 sensors; otherwise why have the expense of 4 when 2 will suffice?
Old 10-05-2010, 10:26 AM   #3 (permalink)
There is a long term fuel trim that can adjust the banks or even individual cyls differently but the O2 sensor is involved only if the exhaust pipes are completely separated before the O2 sensors and cats. On most V engines there is a cross over point before the cats.
Old 10-05-2010, 01:36 PM   #4 (permalink)
EV Wannabe
My 3.0L Mazda Tribute has cats inside the manifolds with 2-O2 sensors on each manifold. It also has a third downstream unmonitored (no sensors) cat.
Old 10-06-2010, 01:04 PM   #5 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
yes - Bank 1 and Bank 2 are independant
yes bank 1 and bank 2 are independant
they share a common load sensor and fuel supply
but fuel trim correction per bank is unique to the bank
the system will trim on the rear 02 sensors as well
if both banks have long term fuel trim corrections that exceed +/- 10% and are the same
the problem is in load calculation or fuel supply or air supply
if only one bank has such an error , the problem only affects that bank
Originally Posted by mechman600 View Post
Quick question:
Curious is all.
The Following User Says Thank You to mwebb For This Useful Post:
MrMiata (10-10-2010)
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 52 05-18-2012 12:52 PM
What does the O2 sensor want? thatguitarguy Off-Topic Tech 2 11-25-2009 07:42 PM
O2 sensor thegasman EcoModding Central 3 07-23-2009 06:04 PM
Cleaning o2 (wideband in this case) sensors? Daox General Efficiency Discussion 2 05-20-2009 07:42 AM
Running "Lean" with a Resistor Divider on the Air Temp Sensor steensn EcoModding Central 22 05-16-2008 09:11 AM
