Old 01-13-2011, 11:40 PM   This thread is in the EcoModder Project Library | #1 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
Astro Grille Block
I am tired of the van never warming up and at best reaching 160 degrees this winter. A grille block is the best way to deal with this as well as maybe even actually helping mileage out a bit. So I made one but I need to be able to take it off so I won't overheat when I have to haul heavy loads. I made it out of vinyl that I sewed the edges over and put grommets on each corner. I have it on there with a bit of rope for now but I will probably use some bungee cords when I get a few more of them that don't have plastic ends so they fit under the hood.
For about 30 minutes worth of work it isn't bad. When I get a better way to hold it down I can get it square over the grille and it will be almost invisible.
I really don't see it helping the mileage much since aerodynamically that thing is a huge square block but it might help a bit. I know the mileage will get better with a warmer engine though.
I also am trying only 20% bio to help the thing run. I guess when the weather stays around 32 degrees bio isn't working out. But if this cover keeps it warmer I might try going a bit more. It has been cold enough I haven't felt like making any bio so does anyone here have experience with just mixing some straight veggie oil in the fuel when it is around 32 degrees average?
