Old 12-12-2007, 07:38 AM   This thread is in the EcoModder Project Library | #1 (permalink)
Stickboy
Send a message via Yahoo to jodydewey
Home-made grille block / bra
Can you take a picture of the bra you have on the front of Blackfly? Also, where did you get it? I figure that is the easiest way to close off the front of the geo without permanently changing it. I want to see how much improvement happens when the front end is closed off.
That spray foam would work well to completely close off the front fenders too. I was thinking of making new front fenders that completely go around the front fenders. I would need foam and fiberglass to make them and then maybe I could get someone to make a mold of them so they could be mass produced.
Jody
Old 12-12-2007, 11:14 AM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Hi Jody -
See the attached pic.
I made this one, actually. It's just a rectangle of outdoor appropriate black vinyl with:
  • a cord attatched at each corner with hooks on the ends to pull it taut horizontally towards the wheel arches
  • five "tabs" (2 top, 3 bottom) to stretch it taut vertically (you can see the 2 top tabs just inboard of the turn signals - they hook on the top aft edge of the bumper cover)
  • a hole for the block heater cord
  • one permanent cooling opening, about 6 in. by 4 in, with a mesh screen (which you can't really see in the pic)
  • there's a second cooling opening (outboard of the permanent one) that has a velcro secured trap door/flap. I put it there just in case, but I've never had to open it.
This took me about 1 to 2 hours to make, and materials cost maybe 15 bucks from a fabric shop.
If you can find a commercial bra designed to fit your car, that would be the easiest route. But you would obviously have to modify it (it would still have too many openings).
Old 12-12-2007, 11:18 AM   #3 (permalink)
Wait - I almost forgot! This mod cost me more than 15 bucks.
I removed my front licence plate to install it, and somehow (don't ask how) I lost the plate.
I got nabbed by the police in a routine traffic stop / roadside safety dragnet a year ago and was ticketed for the missing plate.
So in fact it cost me more like $110 total.
Old 12-12-2007, 12:22 PM   #4 (permalink)
Stickboy
bra
That is a nice looking setup. I was thinking though I wanted to cover the entire front end all the way back to the front of the wheel openings. Then the only openings would be the headlights.
Old 04-02-2010, 10:28 AM   #5 (permalink)
Looks good.
Old 04-05-2010, 01:27 PM   #6 (permalink)
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
This is the best way IMHO to change the front of a car...
Inexpensive, reversible.
And if one used Styrofoam underneath the bra to make the shape better custom "noses"
could be created relatively cheaply.
This weekend all i did was cover the upper grill on my Camry with cotton fabric and sprayed it several times with old spray paint. Coolant temps at hwy speeds unchanged and only like 5 degrees higher at complete dead stop idle.
So far my mode has cost my only WTF looks from friends and family!
No A-B-A testing.
Tomorrow I will do my weekly 600 mile round trip from Maine to NYC area to work for 3 days. I also changed the gear oil in manual tranny to "mostly" synthetic. (Accidentally bought 1 qt total synthetic and 1 qt synthetic blend).
I digress, great bra, great idea. I plan on doing similar by summer.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
