Old 07-04-2008, 09:53 PM   #11 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I had an '89 Accord and could hear the difference in airflow with the lights popped up.
It's worth mentioning that the mpg hit from the pop up lights up also includes the additional electrical load. So it won't translate exactly to a 4 mpg savings by going to the flush mounts - but it's going to be better than before.
Nice work!
Old 07-08-2008, 12:27 AM   #12 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Honda Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ford Ranchero GT
Spaz - '83 Chevy S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
Thanks for the compliments. I am going to start working nights. I will post the difference in night vs day mileage next week.
Honda...the economical, renewable resource.
Old 07-08-2008, 12:55 AM   #13 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Nice work!
The power being used by the lamps does eat up some power/HP,
but even if the lights weren't on, I could still feel the heavy drag on my 1991 Laser RS when I hit the Flip-up button.
And, when I was zooming along with them already flipped up, and switched on the power to the lamps,
I really didn't feel much of a drag, if any at all..
What is 200W translated into HP?
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 07-08-2008, 06:41 AM   #14 (permalink)
- - '10 Toyota Prius III w/Navi
Hi Xringer,
200/749 is .267 HP
Old 07-08-2008, 08:30 AM   #15 (permalink)
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
Originally Posted by justpassntime View Post
I have had cars before that if the high beams were on the lows were too, I thought they were all that way.
What many folks don't understand is that those "low" beams are actually low/high beams with dual filaments. Thus, while your "low" beam headlights were on with the highs, they were on high beam, not low beam. The headlights you installed and many new headlights only have a single filament per headlight.
Old 07-08-2008, 09:22 AM   #16 (permalink)
Originally Posted by donee View Post
Hi Xringer,
200/749 is .267 HP
Dang!! Seems like those rap guys with the 800 watt subwoofers are wasting
a considerable amount of gas while annoying everyone in the neighborhood..
Heck, the power going to my high beams could power an E-Bike for miles!!
Cheers,
Rich
Old 11-18-2008, 02:36 AM   #17 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I know this thread is old, but I'm sure since it's linked on the mods thread, people see it, and this quote, which is not wholly correct.
Dual filament bulbs turn off one filament in favor of the other, so only one at a time is on. If they were wired correctly, both could be used, but the heat would destroy them quickly. This is most common with sealed beam single-headlight (per side) designs.
Now, Look at EF/ED Honda Civics (These I know for sure). They're Two-bulb composites (per side).
When you turn the headlights to low beam, the low beams come on. When you turn the headlights to hi-beam, the lows stay on, and the highs come on. Thus, 4 headlight setup, all working at the same time. These bulbs are 9005/9006, by the way, so they're not dual filament bulbs.
While one could argue that this is inefficient, removing the wiring and such to stop this action, and make only the highs come on when the highs are on, and only have the lows on when it's the selection, would ultimately be a waste of time. The physical energy would be better spent utilizing some other method than attempting to gain .1 HP of efficiency loss.
Verdict: Wiring all four headlights to work at the same time in tandem while in hi-beam mode is safer due to added lighted area, and saying that it's a waste of efficiency is simply splitting hairs to find a reason to say someone else was wrong.
BTW, OP, nice job on the hood... looks spiffy as a clean unit. Don't forget to remove the motors and frames under those buckets... extra weight
Old 11-23-2008, 01:21 AM   #18 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
that looks pretty trick, like it came that way from the factory..
gives the front end a more agressive look if ya ask me..
Old 03-15-2009, 09:04 PM   #19 (permalink)
LarryClapp's Avatar
Zombie Response Vehicle - '88 Chevy Blazer Silverado
I need to do this to mine. How long did this take to do?
Four more mpg, would be nice. I would bet side mirrors are costing us the same mileage as lights.
fender skirts
1989 crx si fender skirts crexcrex Aerodynamics 26 07-18-2008 03:06 AM
87 Accord LXi Mods justpassntime EcoModding Central 0 06-28-2008 02:05 AM
Considering fender skirts Johnny Mullet Aerodynamics 7 05-17-2008 10:01 PM
Addition of low profile rear spolier- Toyota Corolla TimboliahPantsOnFiyah Aerodynamics 2 04-22-2008 09:18 PM
